BT.com
Wishlist
XYZ XYZ da Vinci Junior
£262.06
More than 50 in stock
£262.06
Add to wishlist
Delivery
Standard 1-3 working days
Marketing description is not available.
XYZprinting da Vinci Junior 1.0 - 3D printer
Printer Type
3D printer - FFF
Max Build Size
150 x 150 x 150 mm
Resolution
0.1 - 0.4 mm
USB 2.0
Card Reader
Build Materials Supported
Polylactide (PLA)
Microsoft Windows 7 or later, Apple MacOS X 10.8 or later
42 cm x 43 cm x 38 cm
Printer Type
3D printer
Fused Filament Fabrication (FFF)
Printer
Built-in Devices
2.6 inch LCD display
Wired
USB 2.0
Resolution
0.1 - 0.4 mm
Input File Formats Supported
STL, 3w
Card Reader
Card reader
Supported Flash Memory Cards
SD Memory Card
Media Handling
Polylactide (PLA)
Max Build Size
150 x 150 x 150 mm
Filament Diameter
1.75 mm
1 x USB 2.0 - 4 pin USB Type B
System Requirements Details
RAM 4 GB
42 cm
43 cm
38 cm
Width (Shipping)
54.7 cm
Depth (Shipping)
58.1 cm
Height (Shipping)
47.5 cm
Weight (Shipping)
15 kg
Scroll to top
