BT.com
Wishlist
XYZ PLA Filament 1.75mm Clear Yellow
XYZ PLA Filament 1.75mm Clear...
£27.67
6 in stock
£27.67
Add to wishlist
Delivery
Standard 3-5 working days
PLA filaments are extracted from biodegradable materials. In addition to being environmentally friendly, it is also suitable for lower temperature printing methods that greatly reduce the warpage along the edges of the printed good. The translucent texture and finishing will also add a unique feature to your finished work.
Easy to install filament cartridges available in many vivid colors. XYZprinting filament cartridges are designed and tested to ensure that there is no distortion in color or form ensuring your designs come out perfect every time.
PLA materials printed at low temperatures are not only suitable for family settings, its bright texture also makes it a favorite amongst the clients. You may observe the characteristics of PLA during printing.
Despite their harmlessness, PLA placed in an environment or water bath exceeding 50°C (122°F) will soften and deform. Hence, overly humid areas are not suitable storage environments for PLA.
A sugary smell is often generated when printing with PLA filaments, giving yet another attractive feature.
Additionally, PLA can also be used as a component for composite materials. Materials can be printed using both PLA and the water soluble PVA at the same time using dual nozzle 3D printers. Once printing is complete, you may place the combined material in water to completely dissolve the water-soluble PVA material, giving you an intricate work of art.
Environmentally friendly material. XYZprinting filament cartridges are designed and tested to ensure that there is no distortion in color or form ensuring your designs come out perfect every time.
The XYZprinting Filament Cartridges have versatile materials allowing you to make quick models or detailed products with your da Vinci 3D printer.
XYZprinting's vividly colored filament is engineered and tested to make sure that there is no distortion in the color and form of the filament.
XYZprinting - clear yellow - PLA filament
PLA filament
Filament Diameter
1.75 mm
600 g
Printing Technology
FDM
Printing Colour
Clear yellow
Consumable
Consumable Type
PLA filament
Filament Diameter
1.75 mm
600 g
Printing Technology
FDM
Clear yellow
Nozzle Temperature
190 °C
Glass Transition Temperature
45 °C
Scroll to top
