BT.com
Wishlist
XYZ ABS Filament 1.75mm Violet
£22.18
9 in stock
£22.18
Add to wishlist
Delivery
Standard 3-5 working days
XYZprinting produces high quality ABS filaments that offer longer lifespan, better impact resistance, and finer appearance that makes it suitable for external components or model parts. Additionally, you can easily use common modeling tools to decorate, assemble or connect different parts to create your perfect work.
Easy to install filament cartridges available in many vivid colors. XYZprinting filament cartridges are designed and tested to ensure that there is no distortion in color or form ensuring your designs come out perfect every time.
The XYZprinting filament is extensively tested on the da Vinci and XYZware to ensure that it performs consistently to the highest standards of 3D printing.
XYZprinting's vividly colored filament is engineered and tested to make sure that there is no distortion in the color and form of the filament.
The XYZprinting filament has been designed to be easy to install and replace. The da Vinci will also notify you when the filament is running low so you don't run out.
XYZprinting - violet - ABS filament
ABS filament
600 g
Printing Technology
FDM
Printing Colour
Violet
Compatible with
Da Vinci 1.0, 1.0 Aio
Consumable
Consumable Type
ABS filament
600 g
Printing Technology
FDM
Violet
Compatible with
XYZprinting da Vinci 1.0, 1.0 Aio
Scroll to top
