BT.com
Wishlist
XIGMATEK XLF-F1454 LED Fan
Delivery
Standard Due date unavailable
XLF-F1454, 140mm LED cooling fan catches not only your eyes, but it also performs adding more airflow in your PC case. It comes with maximum 1000 RPM and 63.5 CFM and also with quite level. Shinning LED light and transparent colorific frame/blade make your PC case a spotlight. To make your PC case a spotlight and outstanding performance, XLF-F1454 is the optimal choice.
XIGMATEK XLF-F1454 - case fan
Case fan
Package Content
Screws, 3-pin plug to 4-pin Molex adapter
Fan Diameter
140 mm
Fan Height
25 mm
Fan Bearing
Long Life Bearing
Rotation Speed
1000 rpm
Air Flow
63.5 cfm
Noise Level
16 dBA
Power Connector
3-pin plug
Rated Voltage
12 V
White LED x4
14 cm x 14 cm x 2.5 cm
Case fan
Package Content
14 cm
14 cm
2.5 cm
Heatsink & Fan
Fan Diameter
140 mm
Fan Height
25 mm
Fan Bearing
Long Life Bearing
Rotation Speed
1000 rpm
Air Flow
63.5 cfm
Noise Level
16 dBA
Power Connector
3-pin plug
Rated Voltage
12 V
White LED x4
Scroll to top
