Click to visit BT.com
BT.com
Wishlist
XIGMATEK Praeton LD963 CPU Cooler
Quicklinx: 8DCVWS00
Mfr#: CAC-D9HH3-U01
The Xigmatek PRAETON LD963 is an intelligent evolution of the original LD964 design. The redesigned PRAETON LD963 focused on improving both thermal efficiency and cost. Despite reducing the number of 6mm heatpipes from four to three, the LD963 performs better than its predecessor while still maintaining the same compact form-factor.
The PRAETON LD963 is capable of handling up to 115W of heat generated by the CPU. Paired with a 90mm 4-pin PWM fan for silent and efficient operation, the PRAETON LD963 provides excellent performance and value for your money. The PRAETON LD963 supports Intel Socket LGA 1366/1156/1155/775 and AMD Socket FM1/FM2/AM2/AM2+/AM3/AM3+.
Featrues
  • Superior thermal design handles up to 115W of power
  • Powerful 90mm 4-pin PWM controlled fan provides efficiency along with massive 48CFM airflow
  • Designed for silent operation - 2800RPM at 22dBA
  • Attractive styling features Xigmatek Orange-bladed fan
  • Slim, low-profile aluminum fins integrates with three high-efficiency heat-pipes
  • Easily installs on Intel LGA1366/1156/1155/775 and AMD FM1/FM2/AM2/AM2+/AM3/AM3+
  • 1 Year Manufacturers Warranty
  • Product Name: Praeton LD963
  • Product Number: CAC-D9HH3-U01
  • Dimension: 104(W) x 93(D) x 44(H) mm
  • Heat Sink: Base Material H.D.T. (Heat-pipes Direct Touch), Fin Material Aluminum Alloy
  • Heat-pipe: SPEC F6mm, Q´ty 3 pcs
  • Fan: Dimension 90(W) x 90(H) x 15(D) mm, Voltage Rating 12V, Speed 1200~2800 R.P.M, Bearing Type Hydraumatic, Air Flow 48 CFM (Max.), Air Pressure 3.9 mmH2O (Max.), M.T.B.F. 40,000 hrs, Noise Level 22dBA (Max.), 4 pin with PWM 1 pcs., Weight 202g (Sink Only)
  • Thermal Resistance: 0.22 ?/W
  • TDP: 115W
  • Warranty: 1 Year Manufacturers Warranty
XIGMATEK Praeton LD963 - processor cooler
Processor cooler
Compatibility
LGA775 Socket, LGA1156 Socket, Socket AM2, Socket AM2+, LGA1366 Socket, Socket AM3, LGA1155 Socket, Socket AM3+, Socket FM1, Socket FM2
Heatsink Material
Aluminium
Fan Diameter
90 mm
Fan Height
15 mm
Fan Bearing
Hydraumatic bearing
Rotation Speed
1200-2800 rpm
Air Flow
48 cfm
Noise Level
22 dBA
Power Connector
4-pin fan connector
Heat-pipe Direct Touch (H.D.T.) Technology, Pulse-width modulation (PWM) support, 3 heatpipes
10.4 cm x 9.3 cm x 4.4 cm
Processor cooler
10.4 cm
9.3 cm
4.4 cm
Heatsink & Fan
Compatible With
Heatsink Material
Aluminium
Thermal Resistance
0.22 °C/W
Fan Diameter
90 mm
Fan Height
15 mm
Fan Bearing
Hydraumatic bearing
Rotation Speed
1200-2800 rpm
Air Flow
48 cfm
Air Pressure
3.9 mm
Noise Level
22 dBA
Power Connector
4-pin fan connector
MTBF
40,000 hour(s)
