BT.com
Wishlist
XIGMATEK Crystal 120mm Purple LED Fan
Delivery
Standard Due date unavailable
LED Fan Crystal series, comes with Quad LEDs and transparent frame a blades. Combination design of special and large fan blade and efficient frame, Crystal series performs pushing maximum airflow and min. amount of noise. To choose a quiet, reliable, skinny and outstanding case fan, LED fan Crystal series is your best choice.
XIGMATEK CLF-F1255 - case fan
Case fan
Package Content
3-pin plug to 4-pin Molex adapter, 4 screws
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
Long Life Bearing
Rotation Speed
1500 rpm
Air Flow
68.3 cfm
Noise Level
20 dBA
Power Connector
3-pin plug
Rated Voltage
12 V
Multicolour LEDs
12 cm x 12 cm x 2.5 cm
Case fan
Package Content
12 cm
12 cm
2.5 cm
Heatsink & Fan
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
Long Life Bearing
Rotation Speed
1500 rpm
Air Flow
68.3 cfm
Noise Level
20 dBA
Power Connector
3-pin plug
Rated Voltage
12 V
Start Voltage
7 V
Multicolour LEDs
Scroll to top
