Click to visit BT.com
BT.com
Wishlist
XIGMATEK Asgard III Case
Quicklinx: 7PP6WS00
Mfr#: CCC-AE45TS-U01
As the country of Gods, the inviolable Asgard-III is the world's first black coating entry-level chassis - milestone. Furthermore this chassis is supplied with 1 x 120 mm pre-installed black fan, and 3 more fans can be mounted in different areas for best possible airflow. 4 x 5.25" bays will be able to house all your optical drives, so you can feel free by "DIY". Tool free design and a "gorgeous" outlook are only a few points why this chassis is a "must" not only for enthusiast but also for PC beginners.
XIGMATEK Asgard-III - mid tower - ATX
System cabinet
Mid tower
I/O Connectors
2 x USB 2.0 , 1 x audio line-out , 1 x microphone
Supported Motherboards
ATX, microATX
Power supply
Specification Compliance
ATX12V / EPS12V
18.5 cm x 47.5 cm x 40.8 cm
Mid tower
Max Mainboard Size
ATX
ATX, microATX
ATX12V / EPS12V
Internal Bays Qty
5
Front Accessible Bays Qty
5
Cooling System
Rear : 120 mm fan x 1 , Side : 80/90/120 mm fan mount x 2 , Front : 80/90/120 mm fan mount x 1
Expansion Bays
3 (total) / 3 (free) x front accessible - 5.25" , 2 (total) / 2 (free) x front accessible - 3.5" , 5 (total) / 5 (free) x internal - 3.5"
Expansion Slots
7 x Expansion Slot
2 x USB 2.0 , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack
Power supply
18.5 cm
47.5 cm
40.8 cm
