BT.com
Wishlist
XIGMATEK 500W Tauro 80 Plus Bronze Power Supply
Delivery
Standard Due date unavailable
Powerful and efficient during warfare and a master of weapons - what is it that you expect from your power supply's nowadays. Tauro series PSUs will become your new heroes. Extreme efficient, meshed cable management, stability on all rails, low noise and 80 plus Bronze certification are some of advantages of our new PSUs.
  • Quiet, stable, and efficient power supply with 80Plus Bronze certificate.
  • Very stable voltage regulation and very clean DC output quality.
  • 12V single rail with high compatibility to support high-end system configuration.
  • Over 85% efficiency and meet official 80Plus Bronze certificate.
  • Great DC output quality by low ripple noise and low voltage regulation.
  • Stable and continuous output in 50°C ambient temperature.
  • Low noise by thermal fan controlled 13.5cm silent fan and two voltage synchronized 3pin connetors.
  • Universal AC input by active PFC and up to 0.99 PF rate.
  • Compliant with latest EU ErP Direction.
  • Fully safety certificate with CE, FCC, TUV, and UL.
  • Complete electric protection by OVP, OCP, UVP, OTP, OPP, and SCP.
XIGMATEK Tauro XTK-TB-0500A - power supply - 500 Watt
Power supply - active Power Factor Correction (PFC) - internal
Specification Compliance
ATX
80 PLUS Certification
80 PLUS Bronze
Input Voltage
AC 115/230 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
500 Watt
Output connectors
1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin +12V with detachable 4 pin section , 2 x 8 pin PCI Express power with detachable 2 pin section , 4 x 4 PIN internal power , 1 x 4 PIN mini-power connector , 5 x 15 pin Serial ATA power
Cooling System
140 mm fan
15 cm x 16 cm x 8.6 cm
ATX
Input Voltage
AC 115/230 V
Frequency Required
50 - 60 Hz
Output Voltage
+3.3, +5, ±12 V
Power Capacity
500 Watt
Output Current
+3.3V - 24 A / 0.5 A , +5V - 24 A / 0.5 A , +12V - 32 A / 1 A , -12V - 0.5 A / 0 A , +5VSB - 2.5 A / 0.1 A
Efficiency
85%
80 PLUS Bronze
Power cable - external
MTBF
100,000 hours
Cooling System
140 mm fan
Over current protection, over voltage protection, overpower protection, undervoltage protection, short-circuit protection, single 12V rail, thermal protection
UL, TUV, FCC, ERP
50 °C
10 - 90% (non-condensing)
Sound Emission
28.72 dBA
15 cm
16 cm
8.6 cm
Scroll to top
