BT.com
Wishlist
XFX ATI Radeon 7970 1GHz 3GB PCI-Express HDMI Dual Fan Black Etn
Free delivery
Delivery
Standard Due date unavailable
AMD Radeon™ HD 7970: A Quantum Leap In Graphics Technology
The AMD Radeon HD 7970 graphics processor harnesses the visionary GCN architecture. As the world's first 28 nm GPU, this chip is primed to enable astonishing performance and breathtaking image quality, making it the only solution for gamers who expect the best.
The XFactor - See The XFX Difference: Quality components, greater durability
  • Solid Capacitors
  • Ferrite Core Choke
  • 2oz Copper Layer
  • Dust-Free IP-5X Fan
  • XFX Bracket Design
Edging Out The Competition
High quality DURATEC components allow us reduce power loss while pushing clock speeds to the edge at the same time.
Maximize Your Gaming Experience: Multi-Monitor and Stereoscopic 3D
  • Up to 3 Displays
  • Independent resolutions & controls
  • 16K x 16K Resolutions
  • Combine multiple
  • Active and Passive 3D
Next Generation Gaming Graphics: Ultra-Realistic 3D Gaming With DirectX® 11 Technology.
  • 2X Faster Tessellation
  • 24X Multi-Sample Anti-Aliasing (MSAA)
  • Horizon-Based Ambient Occlusion (HBAO)
  • Particle Physics & Fluid Dynamics
  • Shader Model 5.0
  • DirectCompute 11 & OpenGL 4.2 Support
  • Multi-threading
  • HDR texture Compression
Next Generation Performance: A Quantum Leap In Architecture And Processing Power, DoubleThe Bandwidth.
  • GCN Architecture with a new compute core.
  • 28 Nanometers
  • 384-bit Memory
  • PCI Express 3.0 - 32GB/s bandwidth & 8GHz)
  • 3GB Memory On-Board
*Specifications
  • Chipset version:ATI Radeon HD 7970
  • GPU Clock:1000 MHz
  • Memory Bus:384 bit
  • Memory Clock:5.7 GHz
  • Memory Size:3 GB
  • Memory Type:DDR5
  • AMD Eyefinity Technology:Y
  • AMD HD3D Technology:Y
  • AMD - CrossFire ready:Y
  • HDMI Ready:1.4a
  • Max Supported Resolution (ANALOG):2048 x 1536
  • Max Supported Resolution (DIGITAL):2560 x 1600
  • Output - DL-DVI-I:1
  • Output - HDMI:1
  • Output - mini DP:2
  • Dual link Support:Y
  • Display Port ready:1.2
  • Card Dimension (cm):27.5 x 11.12 x 3.81
  • Card Dimension (inch):10.8 x 4.4 x 1.5
  • Card Profile:Dual
  • Thermal Solution:HD7970 MBA Ghost Dual fan fansink
  • Thermal Type:Dual slot
Requirements
  • External Power - 6-Pins:1
  • External Power - 8-Pins:1
  • Minimum Power Supply Requirement:500 watt
  • XFX Recommended Power Supply:XFX 650W PSU
XFX Radeon HD 7970 - Black Edition - graphics card - Radeon HD 7970 - 3 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
AMD Radeon HD 7970
3 GB - GDDR5
Core Clock
1000 MHz
Stream Processors
2048
Effective Memory Clock
5.7 GHz
Memory Interface
384-bit
Max Resolution
2560 x 1600
Max Resolution Details
DVI: 2560 x 1600 / DisplayPort: 2560 x 1600 / HDMI: 2560 x 1600 / VGA: 2048 x 1536
Max Monitors Supported
3
DVI-I (dual link) , HDMI , 2 x Mini DisplayPort
API Supported
DirectX 11, DirectCompute 11, OpenGL 4.2, OpenCL 1.2
3.8 cm x 27.5 cm x 11.1 cm
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
AMD Radeon HD 7970
Core Clock
1000 MHz
Stream Processors
2048
Max Resolution
2560 x 1600
3
API Supported
Integrated 7.1 channel HD Audio controller, High dynamic-range (HDR) rendering, Avivo HD Technology, AMD Eyefinity Technology, AMD HD3D Technology, AMD Accelerated Parallel Processing (APP) Technology, AMD PowerPlay technology, AMD CrossFireX Technology, AMD Stream technology, AMD Hybrid Graphics Technology, Dust-proof fan, solid state capacitors, AMD App Acceleration, Adaptive Anti-Aliasing, Morphological Anti-Aliasing (MLAA), Super-Sample Anti-Aliasing (SSAA), Ghost Dual fan fansink, XFX HydroCell
Size
3 GB
GDDR5 SDRAM
Effective Clock Speed
5.7 GHz
Bus Width
384-bit
Microsoft Windows Vista / XP / 7
Required Power Supply
500 W
Additional Requirements
Adjacent PCI slot, 6-pin + 8-pin power connectors
CrossFire bridge
Software Included
Drivers & Utilities
3.8 cm
27.5 cm
11.1 cm
Scroll to top
