BT.com
Wishlist
XFX ATI Radeon 6870 900MHz 1GB PCI-Express HDMI
Delivery
Standard Due date unavailable
The AMD Radeon HD 6870 is 3-D ready and one of the first HDMI and DisplayPort 1.2 solutions for Stereoscopic 3-D on the market. The AMD Radeon HD 6870 ushers in a new era of gaming that takes users to an entirely new level. The AMD 3-D experience is truly immersive and seamless. AMD has also teamed up with other Open 3-D ecosystem partners to provide consumers with more choice, more innovation and lower cost. Along with the series XFX debuts the 3E Trilogy, incorporating AMD eye-definition, AMD Eyefinity and AMD Eyespeed technologies.
XFX Radeon HD 6870 Standard graphics card - Radeon HD 6870 - 1 GB
Graphics card
Bus Type
PCI Express 2.1 x16
Graphics Engine
AMD Radeon HD 6870
1 GB - GDDR5
Core Clock
900 MHz
Effective Memory Clock
4.2 GHz
Memory Interface
256-bit
Max Resolution
2560 x 1600
Max Monitors Supported
4
2 x DVI-I , HDMI , 2 x Mini DisplayPort
API Supported
DirectX 11, OpenGL 3.2
3.8 cm x 22 cm x 11.1 cm
Graphics card
Bus Type
PCI Express 2.1 x16
Graphics Engine
AMD Radeon HD 6870
Core Clock
900 MHz
Max Resolution
2560 x 1600
4
API Supported
ATI Stream technology, ATI CrossFireX Technology, ATI PowerPlay technology, Video Transcoding (AVT), AMD Eyefinity Technology, AMD HD3D Technology, AMD Accelerated Parallel Processing (APP) Technology, AMD Eyespeed, AMD Eye-Definition, fan-cooled heatsink, AMD Unified Video Decoder (UVD) 3
Size
1 GB
GDDR5 SDRAM
Effective Clock Speed
4.2 GHz
Bus Width
256-bit
Required Power Supply
550 W
Additional Requirements
PCIe slot
Software Included
Drivers & Utilities
RoHS
3.8 cm
22 cm
11.1 cm
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Great!
Reviewed by Anonymous on 02/02/2012
Bought this instead of a VTX3D 6950, after having to RMA it. Surprisingly, this card seems to give me very similar results! This card feels like almost 90% of a 6950, only downside, is that it is 1Gb, so eyefinity is sort of good, but not great (very slight stutters in 4320x900, BF3 on auto)
All in all, for a card that is certainly ageing, it sure still packs a punch like the 6950 does now, and also, price:performance of a 6950 compared to this, if a 6950 was £200, this is currently £120, so if this gives out 90%, your paying a better price for the same thing!
Only downside of this card, is that it is quite loud, if you hate stock AMD processor fans, this really will make your computer take off!
Eyefinity, And the catalyst drivers are very easy to use, once I setup eyefinity, loaded up a game, and it was working without touching graphics settings!
4* Nice performance, bit noisy.
Reviewed by Sam on 01/10/2012
Works lovely, and the price is reasonable for a card of this level. However it really is quite a noisy card, I had to purchase a 3rd party fan kit for another thirty pounds to solve the noise issues.
3* I confirm this card is noisy!
Reviewed by Lam Huynh on 06/03/2012
I can confirm with that this card is very noisy under normal use and even more noisy under gaming.
I sent it back and purchased a Sapphire 6870 which is quiet and pleasant. You can watch a movie and can barely hear it.
3* LOUD!!!!!!!!!!
Reviewed by Dan on 23/10/2011
Okay, so yes, this card did play Battlefiled Bad Company 2 with all video settings on Max, it was smooth and looked great. BUT..... Under load it is LOUD! The loudest graphics card I have ever owned. It sounded like a hair dryer of full blast! So loud infact that I could hear it through my headphones. After 1 hour of it being in my machine I requested an RMA from BT under the 7 day return policy, sent in back and bought the Sapphire HD6870 instead which my friend has and says has cannot hear it even under load over his case fans. So there you go. IMO, go for the Sapphire card, it's £10 more but well worth it.
Scroll to top
