BT.com
Wishlist
XFX ATI Radeon 6850 HD 775MHz 1GB PCI-Express HDMI
Delivery
Standard Due date unavailable
AMD Radeon™ HD 6850: XFX KEEPING IT REAL
With the 6000 series, XFX is literally putting you in the game. The AMD Radeon HD 6850 is 3-D ready and one of the first HDMI 1.4a and DisplayPort 1.2 solutions for Stereoscopic 3-D on the market.
The AMD Radeon HD 6850 ushers in a new era of gaming that takes users to an entirely new level. The AMD 3-D experience is truly immersive and seamless. AMD has also teamed up with other Open 3-D ecosystem partners to provide consumers with more choice, more innovation and lower cost.
This high-speed graphics card outdoes the competition with 775MHz, a 4 GHz memory clock, DP + HDMI + Dual DVI which allows for play across four screens and a shader speed of 800 to ensure that graphics are crisp and life-like.
Along with the new series XFX debuts the 3E Trilogy, incorporating AMD Eye-Definition (utilizing AMD's HD3D technology & DirectX 11 for explosive performance and stunning effects), AMD Eyefinity (which supports multi-display gaming) and AMD Eyespeed (improves video image quality and application performance for amazing visuals) technologies.
The AMD Radeon HD 6850 offers no compromise performance with flawless image quality so users aren't just playing the game - they're in it.
XFX RADEON HD 6850 graphics card - Radeon HD 6850 - 1 GB
Graphics card
Bus Type
PCI Express 2.1 x16
Graphics Engine
AMD Radeon HD 6850
1 GB - GDDR5
Core Clock
775 MHz
Effective Memory Clock
4 GHz
Memory Interface
256-bit
Max Resolution
2560 x 1600
Max Resolution Details
DVI: 2560 x 1600 / DisplayPort: 2560 x 1600 / HDMI: 2560 x 1600 / VGA: 2048 x 1536
Max Monitors Supported
4
2 x DVI-I , HDMI , DisplayPort
API Supported
DirectX 11, OpenGL 3.2
3.8 cm x 23.5 cm x 11.2 cm
Graphics card
Bus Type
PCI Express 2.1 x16
Graphics Engine
AMD Radeon HD 6850
Core Clock
775 MHz
Max Resolution
2560 x 1600
4
API Supported
ATI CrossFireX Technology, ATI PowerPlay technology, Video Transcoding (AVT), AMD Eyefinity Technology, AMD HD3D Technology, AMD Accelerated Parallel Processing (APP) Technology, AMD Eyespeed
Size
1 GB
GDDR5 SDRAM
Effective Clock Speed
4 GHz
Bus Width
256-bit
Linux, FreeBSD, Microsoft Windows Vista / XP / 7
Required Power Supply
500 W
Additional Requirements
Additional power connector, adjacent PCI slot, PCIe slot
System Requirements Details
Windows XP/Vista/7 - RAM 1 GB
Software Included
Drivers & Utilities
RoHS
3.8 cm
23.5 cm
11.2 cm
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
3* Better off with a different card
Reviewed by Stefan on 08/01/2011
The new 6000 series have failed to impress me. When my card arrived I had been disappointed by the packaging it came in, there was no foam and the only thing that held the card in place was the cardboard it was mounted on. Once I installed the card, everything was fine and easy to do but the real issue was of how bad the quality of the card was and how terrible graphics were. For the price this card is based at, I would recommend avoiding it and going for a different card, BT should be selling these cards at 100 pounds or less and not be charging 150
2* Poor build quality
Reviewed by Anonymous on 22/06/2011
I received my XFX 6850 earlier this year. Fan has started to make very loud noises and card is constantly overheating under a relatively light load. Sent back to BT for a refund.
Scroll to top
