BT.com
Wishlist
XFX AMD Radeon R7 260X 2GB PCI-Express 3.0 HDMI
Delivery
Standard Due date unavailable
  • GPU Clock 1075 MHz
  • Memory Bus 128 bit
  • Memory Clock 6.4 GHz
  • Memory Size 2 GB
  • Memory Type DDR5
  • Thermal Solution Dual Slot Thermal
  • Minimum Power Supply Requirement 500 watt
  • XFX Recommended Power Supply XFX 550W PSU
  • External Power - 6-pins 1
  • Dual link Support Y
  • Max Supported Resolution (ANALOG) 2048 x 1536
  • Max Supported Resolution (DIGITAL) 2560 x 1600 (DVI); 4096 x 2160 (HDMI;DP)
  • Output - Displayport 1
  • Output - HDMI 1
  • Output - DL-DVI-I 1
  • Output - DL-DVI-D 1
  • Card Dimension (cm) 177 x 11.12 x 3.81
  • Card Dimension (inch) 7.0 x 4.4 x 1.5
  • Card Profile Dual
  • Display Port ready 1.2
  • HDMI Ready 1.4a
  • Low Profile Compatible N
  • Duratec IP5X Dust Free Y
  • Duratec Solid Capcitors Y
  • Fan Ramping Y
Technologies
  • AMD Eyefinity Technology Y
  • AMD HD3D Technology Y
  • Ghost Thermal Technology 2.0
  • PowerTune 2.0
Package Contents
  • Driver CD Installation Guide 1
  • Installation DVD 1
  • Promotional Bundles PSU Cross Marketing Insert
  • Quick Installation Guide 1
  • XFX Serial Number Card 1
  • Warranty Insert for Worldwide 1
XFX Radeon R7 260X - Core Edition - graphics card - Radeon R7 260X - 2 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
AMD Radeon R7 260X
2 GB GDDR5
Stream Processors
896
Memory Interface
128-bit
Max Resolution
4096 x 1600
Max Resolution Details
DVI: 2560 x 1600 / DisplayPort: 4096 x 1600 / HDMI: 4096 x 1600
Max Monitors Supported
4
DVI-D (dual link) , DVI-I (dual link) , HDMI , DisplayPort
API Supported
DirectCompute 11, OpenCL 1.2, OpenGL 4.3, DirectX 11.2
3.81 cm x 17.7 cm x 11.12 cm
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
AMD Radeon R7 260X
Stream Processors
896
Max Resolution
4096 x 1600
4
API Supported
AMD Eyefinity Technology, AMD HD3D Technology, AMD PowerPlay technology, AMD CrossFireX Technology, AMD Stream technology, AMD Hybrid Graphics Technology, Enhanced Quality Anti-Aliasing (EQAA), Adaptive Anti-Aliasing, Morphological Anti-Aliasing (MLAA), Super-Sample Anti-Aliasing (SSAA), AMD HD Media Accelerator, Ghost Thermal Technology, Graphics Core Next (GCN), Blu-Ray 3D Support, Double Precision Floating Point, AMD App Acceleration 2, Intelligent TDP management technology, Partially Resident Textures (PRT), cutting-edge integrated display support, Video Codec Engine (VCE), Multi-stream hardware H.264 encoder, Multi-Stream Transport, Ultra-high resolution texture streaming technology, Advanced Video Color Correction , HDCP
Size
2 GB
GDDR5 SDRAM
Bus Width
128-bit
Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista, Windows 8, Windows 8.1
Required Power Supply
500 W
Software Included
Drivers & Utilities, AMD Catalyst Control Center
RoHS
3.81 cm
17.7 cm
11.12 cm
Scroll to top
