BT.com
Wishlist
XFX 850W XXX Semi-Modular 80+ Bronze PSU
Delivery
Standard Due date unavailable
Unique, continuous EasyRail technology enables you to maximize available power and make set-up easy. Stack numerous power-hungry components without fear of crashing. It's also a perfect solution for hardcore gamers.
Enables you to maximize available power and make set-up easy. Stack numerous power-hungry components, such as your GPU, CPU and other components, without fear of crashing. In addition this PSU has also been award the 80 Plus Bronze certification for its high power efficiency and is also designed for NVIDIA SLI and AMD Crossfire multi-GPU systems making it a perfect solution for hardcore gamers.
Conventional PSU uses multi-rail technology which basically combines cheaper and lower wattage PSU into one single PSU to generate a higher total wattage. However, smaller rails have lower maximum wattages so left over wattage on individual rails become too small to handle major components and gets wasted.
XFX ProSeries P1-850X-XXB9 - XXX Edition - power supply - 850 Watt
Power supply - active Power Factor Correction (PFC) - internal
Specification Compliance
ATX12V 2.2/ EPS12V 2.91
80 PLUS Certification
80 PLUS Bronze
Output Voltage
+3.3, +5, ±12 V ± 5%
Power Capacity
850 Watt
Output connectors
1 x 4 PIN mini-power connector , 5 x 4 PIN internal power , 10 x 15 pin Serial ATA power , 4 x 8 pin PCI Express power with detachable 2 pin section , 1 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin EPS12V
Cooling System
135mm fan
5 years warranty
Input Voltage Range
AC 90 - 264 V
Frequency Required
50/60 Hz
Output Voltage
Max Electric Current
9 A
Power Capacity
850 Watt
Output Current
+12V1 - 70 A / 0.6 A , +3.3V - 25 A , +5V - 25 A , +5VSB - 3 A , -12V - 0.5 A
80 PLUS Bronze
1 x power cable - external
Cooling System
135mm fan
Overheat protection, solid capacitors, over current protection, over voltage protection, overpower protection, SLI ready, CrossFire ready, undervoltage protection, short-circuit protection, single 12V rail
FCC Class B certified, TUV, C-Tick, CB
5 years warranty
Service & Support Details
Limited warranty - 5 years
Scroll to top
