BT.com
Wishlist
XFX 850W Black Edition Single Rail Modular Power Supply
Delivery
Standard Due date unavailable
Unique, continuous EasyRail technology enables you to maximize available power and make set-up easy. Stack numerous power-hungry components without fear of crashing. It's also a perfect solution for hardcore gamers.
Enables you to maximize available power and make set-up easy. Stack numerous power-hungry components, such as your GPU, CPU and other components, without fear of crashing. In addition this PSU has also been award the 80 Plus Bronze certification for its high power efficiency and is also designed for NVIDIA SLI and AMD Crossfire multi-GPU systems making it a perfect solution for hardcore gamers.
Conventional PSU uses multi-rail technology which basically combines cheaper and lower wattage PSU into one single PSU to generate a higher total wattage. However, smaller rails have lower maximum wattages so left over wattage on individual rails become too small to handle major components and gets wasted.
XFX ProSeries P1-850B-NLG9 - XXX Edition - power supply - 850 Watt
Power supply - active Power Factor Correction (PFC) - internal
Specification Compliance
ATX12V 2.2/ EPS12V 2.91
80 PLUS Certification
80 PLUS Silver
Output Voltage
+3.3, +5, ±12 V
Power Capacity
850 Watt
Output connectors
1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin EPS12V , 1 x power 4 pin ATX12V connector , 4 x 8 pin PCI Express power with detachable 2 pin section , 8 x 4 PIN internal power , 2 x 4 PIN mini-power connector , 11 x 15 pin Serial ATA power
Cooling System
140 mm fan
Environmental Standards
ENERGY STAR
5 years warranty
Input Voltage Range
AC 90 - 264 V
Frequency Required
47 - 63 Hz
Output Voltage
+3.3, +5, ±12 V
Power Capacity
850 Watt
Output Current
+3.3V - 24 A , +5V - 30 A , +12V - 70 A , -12V - 0.8 A , +5VSB - 3 A
80 PLUS Silver
Cooling System
140 mm fan
Over voltage protection, overpower protection, SLI ready, CrossFire ready, cable management
FCC Class B certified, UL, C-Tick, cUL, CB, RoHS
ENERGY STAR
Limited warranty - 5 years
50 °C
Resources
The following resources are available for the XFX 850W Black Edition Single Rail Modular Power Supply
Scroll to top
