BT.com
Wishlist
XFX 650W 80+ Bronze Certified Single Rail
Delivery
Standard Due date unavailable
Why Choose XFX PSUs?
EasyRail Technology
Don't ever worry about managing rails or running out of power before the max wattage is reached.
Modern Design
Unique industrial design like no other PSU on the market
Multi-GPU Certified (ATI/NVIDIA)
Designed for Multiple GPU gaming setups
Japanese Capacitors
Other PSUs use only some or none - XFX PSUs use ALL, meaning superb quality, longer-lasting PSUs
80Plus Bronze
Our PSUs are efficient - only 15% of the wattage drawn is lost
Clean Power
XFX PSUs are designed to deliver tight DC voltage regulation with minimum AC ripple, giving you safer, cleaner power
Five Year Warranty
XFX PSUs include a comprehensive 5 Year Warranty backed by a highly rated 5 Star Support Service
XFX Core Edition PRO650W - power supply - 650 Watt
Power supply - active Power Factor Correction (PFC) - internal
Specification Compliance
ATX12V 2.2/ EPS12V 2.91
80 PLUS Certification
80 PLUS Bronze
Output Voltage
+3.3, +5, ±12 V
Power Capacity
650 Watt
Output connectors
1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 2 x 6 pin PCI Express power , 2 x 8 pin PCI Express power with detachable 2 pin section , 8 x 15 pin Serial ATA power , 7 x 4 PIN internal power , 1 x 4 PIN mini-power connector
Cooling System
140 mm fan
Environmental Standards
ENERGY STAR
5 years warranty
Input Voltage Range
AC 90 - 264 V
Frequency Required
47 - 63 Hz
Output Voltage
+3.3, +5, ±12 V
Power Capacity
650 Watt
Output Current
+3.3V - 25 A / 0 A , +5V - 25 A / 0 A , +12V - 53 A / 0.6 A , -12V - 0.5 A / 0 A , +5VSB - 3 A / 0 A
80 PLUS Bronze
Cooling System
140 mm fan
SLI ready, CrossFire ready, single 12V rail, ball bearing cooling fan
RoHS
ENERGY STAR
5 years warranty
Service & Support Details
Limited warranty - 5 years
Scroll to top
