Click to visit BT.com
BT.com
Wishlist
XFX 550 Watt Core Edition Full Wired 80+ Bronze PSU
Quicklinx: 7NSWWS00
Mfr#: P1-550S-UKB9
XFX PSUs are designed to deliver tight DC voltage regulation with minimal AC ripple, giving you safer, cleaner power which along with XFX's EasyRail technology allows you to connect numerous devices without worrying about running out of power before reaching the maximum wattage. EasyRail optimizes it all for you.
XFX Core Edition PRO550W - power supply - 550 Watt
Power supply - active Power Factor Correction (PFC) - internal
Specification Compliance
ATX12V 2.2/ EPS12V 2.91
80 PLUS Certification
80 PLUS Bronze
United Kingdom
Input Voltage
AC 100-240 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
550 Watt
Output connectors
1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 1 x 6 pin PCI Express power , 1 x 8 pin PCI Express power with detachable 2 pin section , 9 x 15 pin Serial ATA power , 6 x 4 PIN internal power , 2 x 4 PIN mini-power connector
15 cm x 8.6 cm x 14 cm
Environmental Standards
ENERGY STAR
5 years warranty
United Kingdom
Input Voltage
AC 100-240 V
Input Voltage Range
AC 90 - 264 V
Frequency Required
47 - 63 Hz
Output Voltage
+3.3, +5, ±12 V
Power Capacity
550 Watt
Output Current
+3.3V - 25 A / 0 A , +5V - 25 A / 0 A , +12V - 53 A / 0.6 A , -12V - 0.5 A / 0 A , +5VSB - 3 A / 0 A
80 PLUS Bronze
Over voltage protection, overpower protection, SLI ready, CrossFire ready, undervoltage protection, short-circuit protection, single 12V rail, ball bearing cooling fan
RoHS
ENERGY STAR
5 years warranty
Service & Support Details
Limited warranty - 5 years
50 °C
15 cm
8.6 cm
14 cm
