Click to visit BT.com
BT.com
Wishlist
XFX 450W ProSeries 80Plus Bronze Core Edition Full Wired PSU
Quicklinx: 8DK2WS00
Mfr#: P1-450S-X2B9
The XFX ProSeries PSU with EasyRail™ Technology
Enables you to maximize available power and make set-up easy. Stack numerous power-hungry components, such as your GPU, CPU and other components, without fear of crashing. In addition this PSU has also been award the 80Plus Bronze certification for its high power efficiency and is also designed for NVIDIA SLI and AMD Crossfire multi-GPU systems making it a perfect solution for hardcore gamers. One Rail, One Setup.
Other Power Supply Units
Conventional PSUs use multi-rail technology which basically combines cheaper and lower wattage PSUs into one single PSU to generate a higher total wattage. However, smaller rails have lower maximum wattages so left over wattage on individual rails become too small to handle major components and gets wasted.
Not enough actual wattage - Even though there is technically 50 Watts of power remaining, none of the rails have more than 25W to handle adding a 50W component.
Easyrail™ Power Supply Units
PSUs with EasyRail™ Technology give you one continuous rail of power covering the total maximum wattage. What this means is that no matter how many devices you have, high or low power, they can easily stack until it reaches the full maximum wattage. With EasyRail™ technology you can maximize the potential of your PSU with ease.
Exactly enough actual wattage - Of the 50 Watts of power that you expect to be remaining, all 50W is actually available to easily handle adding a 50W component.
True Wattage Guarantee
The wattage you see isn't always the wattage you get. Some brands tweak tests to achieve great wattage ratings, but in reality, they deliver much lower maximum wattages. Don't be fooled by wattage tricks.
  • Conductive Polymer Aluminum Solid Electrolytic Capacitors
  • Active Power Factor Correction [99% PF Typical]
  • High +12V Output
  • Ultra Ventilation [Grid Structure]
  • Multi-GPU Technologies Supported
  • All-in-One DC Cabling Design
  • Universal AC Input [Full Range]
  • 5 Year Limited Warranty
XFX Core Edition PRO450W V2 - power supply - 450 Watt
Power supply - active Power Factor Correction (PFC) - internal
80 PLUS Certification
80 PLUS Bronze
Output Voltage
+3.3, +5, ±12 V
Power Capacity
450 Watt
Output connectors
1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 1 x 8 pin PCI Express power with detachable 2 pin section , 6 x 15 pin Serial ATA power , 3 x 4 PIN internal power , 1 x 4 PIN mini-power connector
Cooling System
120 mm fan
15 cm x 14 cm x 8.6 cm
5 years warranty
Input Voltage Range
AC 90 - 264 V
Frequency Required
47 - 63 Hz
Output Voltage
+3.3, +5, ±12 V
Power Capacity
450 Watt
Output Current
+3.3V - 20 A , +5V - 20 A , +12V - 34 A , -12V - 0.5 A , +5VSB - 2.5 A
80 PLUS Bronze
1 x power cable
MTBF
100,000 hours
Cooling System
120 mm fan
Gold-plated terminals, over voltage protection, overpower protection, SLI ready, CrossFire ready, undervoltage protection, short-circuit protection, single 12V rail, ball bearing cooling fan
UL, TUV, C-Tick, cUL, CB, FCC Part 15, RoHS, S Mark
5 years warranty
Service & Support Details
Limited warranty - 5 years
50 °C
Sound Emission
38 dBA
15 cm
14 cm
8.6 cm
