BT.com
Wishlist
Xerox WorkCentre 6655V_XM Colour Laser Multifunction Printer
Xerox WorkCentre 6655V_XM Colour...
£1,670.35
£1,670.35
Add to wishlist
Delivery
Standard Due date unavailable
The Xerox WorkCenter 6655V XM Color Multifunction Printer, enabled by Xerox ConnectKey technology, is built for the way you want to work. From cost control and energy savings, to cloud-based scanning solutions and data security, the WorkCenter 6655V XM offers small and medium businesses access to the same solutions typically reserved for larger enterprises.
Xerox 6655V_XM - multifunction printer ( colour )
Fax / copier / printer / scanner
Fax Type
Super G3 - plain paper
Printing Technology
Laser ( colour )
Monthly Duty Cycle (max)
100000 pages
Recommended Monthly Volume
10000 pages
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Up to 35 ppm (mono) / up to 35 ppm (colour)
Max Printing Resolution
Up to 2400 x 600 dpi (mono) / up to 2400 x 600 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
MH, MR, MMR, JBIG
Fax Resolutions
200 x 200 dpi, 200 x 100 dpi, 600 x 600 dpi
Scanning
600 x 600 dpi
Original Size
139.7 x 139.7 mm (min) - Legal (216 x 356 mm) (max)
Original Type
Sheets, books
Document Feeder Capacity
60 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, labels, recycled paper, bond paper, card stock, punched paper
Standard Media Capacity
1250 sheets
Max Media Capacity
1250 sheets
Bypass Feeder Capacity
150 sheets
Output Trays Capacity
250 sheets
Stapler
Included
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
PC Connection Availability
PC Connection
USB 2.0, Gigabit LAN, USB host
AirPrint Enabled
Office Machine Features
Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to network
AC 230 V ( 50/60Hz )
53.8 cm x 55.3 cm x 62.5 cm
37.6 kg
Pricing Type
Xerox Metered Supplies Program
Environmental Standards
ENERGY STAR Qualified , Blue Angel
1 year warranty
Fax Type
Plain paper
Printing Technology
Laser - colour
100000 pages
10000 pages
Display Features
Touch screen
PC Connection
AirPrint Enabled
Standard Memory
4 GB
Hard Disk Drive
250 GB
Copying
Preset Enlargements
400%
Preset Reductions
25%
Maximum Copies
9999
Automatic Duplexing
Copying Features
Auto paper select, auto tray switching, booklet creation, ID Card Copy, collation copy, Edge Erase
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c, PDF, XPS
Automatic Duplexing
First Print Out Time B/W
11 sec
First Print Out Time Colour
11 sec
Scanning
Automatic Duplexing
Optical Resolution
600 x 600 dpi
Grey Scale Depth
8 bit
Colour Depth
24 bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
MH, MR, MMR, JBIG
Fax Resolutions
Fax Machine Features
Speed Dialing
200 station(s)
Automatic redialing, auto reduction, delayed sending, fax polling, fax activity reports, Duplex Fax
Document & Media Handling
Min Original Size
139.7 x 139.7 mm
Max Original Size
Original Type
Sheets, books
60 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), 76.2 x 127 mm, 216 x 356 mm
1250 sheets
Max Media Capacity
1250 sheets
150 sheets
250 sheets
ADF - 60 sheets size: 139.7 x 139.7 mm - Legal (216 x 356 mm) weight: 50 g/m² - 125 g/m² , Bypass tray - 150 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , 2 x input tray - 550 sheets size: 148 x 210 mm - Legal (216 x 356 mm) weight: 60 g/m² - 216 g/m²
Speed Details
Printing: up to 35 ppm ( A4 ) - B/W , Printing: up to 35 ppm ( A4 ) - colour , Scanning: up to 51 ipm - B/W , Scanning: up to 24 ipm - B/W duplex , Scanning: up to 28 ipm - colour , Scanning: up to 13 ipm - colour duplex
Finishing Equipment
Stapler
Included
1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Security Protocols & Features
SSL
Operating System Support
MS Windows XP SP3, MS Windows Vista SP2, MS Windows Server 2008 R2, Apple Mac OS X 10.7, MS Windows Vista SP2 64-bit Edition, MS Windows Server 2008 R2 x64 Edition, Apple Mac OS X 10.8, MS Windows Server 2012, Windows 8, Windows 8 64-bit, MS Windows XP 64-bit Edition SP3 or later, Windows 8.1, Apple Mac OS X 10.9, Windows 8.1 64-bit, MS Windows Server 2012 R2, MS Windows Server 2003 (32/64-bits), MS Windows Server 2008 (32/64-bits), Fedora 19, MS Windows 7 (32/64 bits), Ubuntu Linux 13.10 x64, openSUSE 13.1 x64
486.36 Watt
Power Consumption Standby
71.04 Watt
Power Consumption Sleep
2.71 Watt
First Copy Out Time B/W
15 sec
First Copy Out Time Colour
16 sec
Consumables Included
1 x Cartridge ( black ) - up to 6000 pages , 1 x Cartridge ( magenta ) - up to 3000 pages , 1 x Cartridge ( cyan ) - up to 3000 pages , 1 x Cartridge ( yellow ) - up to 3000 pages
GS, NOM, Directive 1999/5/EC, FCC Part 68, RoHS, UL 60950-1, FCC Part 15 A, FDA, Directive 2004/108/EC, Directive 2006/95/EC, CSA C22.2 No. 60950-1-07 Second Edition, Directive 2011/65/EC, EAC, WEEE 2002/96/EC, CDRH Class 1
Pricing Type
Blue Angel Compliant
Limited warranty - 1 year - on-site
53.8 cm
55.3 cm
62.5 cm
37.6 kg
Shipping Width
67.1 cm
Shipping Depth
67.5 cm
Shipping Height
75.1 cm
Shipping Weight
43.9 kg
Sound Emission
25.1 dBA (idle) / 51.8 dBA (operating)
5 °C
32 °C
15 - 85%
Scroll to top
