BT.com
Wishlist
Xerox WorkCentre 6605N Colour Laser Multifunction Printer
Xerox WorkCentre 6605N Colour Laser...
£540.91
£540.91
Add to wishlist
Delivery
Standard Due date unavailable
With the value-packed WorkCenter 6605 color multifunction printer, today's busy, small workteams can easily make important business communications stand out from the competition with exceptional color printing.
Xerox WorkCentre 6605N - multifunction printer (colour)
Fax / copier / printer / scanner
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
80000 impressions
Max Copying Speed
Up to 35 ppm (mono) / up to 35 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
Data Compression System
MH, MR, MMR, JBIG, JPEG
Scanning
1200 x 1200 dpi
Display
4.3"
Original Size
140 x 140 mm (min) - Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, cards, labels
Standard Media Capacity
700 sheets
Max Media Capacity
1250 sheets
Bypass Feeder Capacity
150 sheets
Output Trays Capacity
250 sheets
Automatic Duplexing
Yes (scanning)
PC Connection Availability
PC Connection
USB 2.0, Gigabit LAN, USB host
Office Machine Features
Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to folder, scan to network
AC 230 V (50/60Hz)
43 cm x 52.8 cm x 56 cm
32.5 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
1 year warranty
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
Laser - colour
80000 impressions
Display Diagonal Size
4.3"
Display Features
Touch screen
PC Connection
Standard Memory
512 MB
Max Supported Memory
1 GB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Copying Features
2 on 1, fit to page, Clone Copy
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PostScript 3, PDF, XPS, PCL 5
First Print Out Time B/W
9 sec
First Print Out Time Colour
10 sec
Colour Management Features
PANTONE Digital Color
Scanning
Automatic Duplexing
Optical Resolution
1200 x 1200 dpi
Grayscale Depth
16-bit
Colour Depth
48-bit
Fax Machine
Fax Machine Features
Speed Dialing
200 station(s)
Broadcast Transmission
Delayed Transmission
Fax forwarding, Distinctive Ring Pattern Detection (DRPD), junk fax barrier, LAN fax, poll receive
Document & Media Handling
Min Original Size
140 x 140 mm
Max Original Size
Original Type
Sheets
50 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
50 g/m²
Max Media Weight
216 g/m²
Supported Media Type
Supported Media Sizes
700 sheets
Max Media Capacity
1250 sheets
150 sheets
250 sheets
ADF - 50 sheets size: 140 x 140 mm - Legal (216 x 356 mm) weight: 50 g/m² - 125 g/m² , Bypass tray - 150 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 216 g/m² , Input tray - 550 sheets size: A5 (148 x 210 mm) - Legal (216 x 356 mm) weight: 60 g/m² - 216 g/m² , Output tray - 250 sheets
Speed Details
Printing: up to 35 ppm (A4) - B/W , Printing: up to 35 ppm (A4) - B/W , Copying: up to 35 ppm (A4) - B/W , Copying: up to 35 ppm (A4) - colour , Scanning: up to 22 ipm (A4) - B/W , Scanning: up to 13 ipm (A4) - colour , Scanning: up to 7 ipm (A4) - B/W duplex , Scanning: up to 4 ipm (A4) - colour duplex
1 x USB 2.0 , 1 x USB host , 1 x Gigabit LAN
Network Protocols
SNMP, HTTPS, IPv6, Bonjour
Security Protocols & Features
LDAP, Secure Print, SSL, IPsec, 802.1x, Secure Fax, IP filtering
Operating System Support
UNIX, Linux, MS Windows XP or later, Apple Mac OS X 10.5 or later
Software Included
Xerox CentreWare Web, Xerox CentreWare Internet Services, Xerox Email Alerts
AC 230 V (50/60Hz)
560 Watt
Power Consumption Standby
72 Watt
Power Consumption Sleep
6 Watt
Warm-Up Time
25 sec
First Copy Out Time B/W
13 sec
First Copy Out Time Colour
16 sec
Consumables Included
1 x Cartridge (black) , 1 x Cartridge (cyan) , 1 x Cartridge (magenta) , 1 x Cartridge (yellow)
ENERGY STAR Certified
Limited warranty - 1 year - on-site
43 cm
52.8 cm
56 cm
32.5 kg
Sound Emission
29 dBA (idle) / 52 dBA (operating)
10 °C
32 °C
10 - 85% (non-condensing)
Resources
The following resources are available for the Xerox WorkCentre 6605N Colour Laser Multifunction Printer
Scroll to top
