BT.com
Wishlist
Xerox WorkCentre 6505DN MFP
£372.90
£372.90
Add to wishlist
Delivery
Standard Due date unavailable
Your busy work-team needs a value-packed color device that gets the job done with the rare combination of outstanding print quality, unparalleled simplicity and day-in, day-out dependability. The WorkCentre 6505 color multifunction printer gives your important documents a powerful, colorful boost. A high print resolution makes your printed communications stand out and grab attention. Xerox exclusive toner uses particles engineered for uniform size and shape, producing superior image detail and line de?nition, and text that's sharp and clear. Pantone Color approved solid-color simulations and Xerox color correction technology ensure results that match your expectations.
Connect and go, thanks to built-in networking and seamless compatibility with mixed-user environments, including PC, Macintosh and Linux. With Xerox CentreWare IS, remote device administration is handled with ease right from your computer's browser. The device features a small footprint, which allows for easy integration within your work space, whether on your desk or in a shared location. The value-packed WorkCentre 6505 multifunction printer will save on energy and supplies costs by combining the functions of multiple devices into one.
Xerox WorkCentre 6505DN - multifunction printer ( colour )
Fax / copier / printer / scanner
Copier Type
Digital
Fax Type
Super G3 - plain paper
Printing Technology
Laser ( colour )
Monthly Duty Cycle (max)
40000 impressions
Max Copying Speed
Up to 23 ppm (mono) / up to 23 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
MH, MR, MMR, JBIG, JPEG
Fax Resolutions
400 x 400 dpi
Scanning
1200 x 1200 dpi
Original Size
140 x 140 mm (min) - Legal (216 x 356 mm) (max)
Original Type
Sheets, books
Document Feeder Capacity
35 sheets
Media Size
76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, cards, labels
Standard Media Capacity
250 sheets
Max Media Capacity
500 sheets
Bypass Feeder Capacity
1 sheet
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (printing)
PC Connection Availability
PC Connection
USB 2.0, Gigabit LAN, USB host
Office Machine Features
Save to USB flash drive, scan to e-mail
AC 230 V ( 50/60Hz )
43 cm x 54.4 cm x 58.4 cm
29.6 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified , EPEAT Silver
1 year warranty
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
Laser - colour
40000 impressions
PC Connection
Standard Memory
256 MB
Max Supported Memory
768 MB
Supported Flash Memory
USB flash drive
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Copying Features
2 on 1, fit to page, ID Card Copy, Clone Copy
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PostScript 3
Image Enhancement Technology
4-bit depth colour technology
Automatic Duplexing
First Print Out Time B/W
12 sec
First Print Out Time Colour
12 sec
Scanning
Optical Resolution
1200 x 1200 dpi
Grey Scale Depth
8 bit
Colour Depth
24 bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Fax Resolutions
400 x 400 dpi
Fax Machine Features
Broadcast Transmission
Delayed Transmission
Fax forwarding, e-mail function, colour faxing, LAN fax
Document & Media Handling
Min Original Size
140 x 140 mm
Max Original Size
Original Type
Sheets, books
35 sheets
Min Media Size
76 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
216 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm)
250 sheets
Max Media Capacity
500 sheets
1 sheet
150 sheets
ADF - 35 sheets size: 140 x 140 mm - Legal (216 x 356 mm) weight: 50 g/m² - 125 g/m² , Bypass tray - 1 sheet size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 216 g/m² , Input tray - 250 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 216 g/m² , Output tray - 150 sheets
Speed Details
Printing: up to 23 ppm ( A4 ) - B/W , Printing: up to 23 ppm ( A4 ) - colour
1 x USB 2.0 , 1 x USB host , 1 x Gigabit LAN
Network Protocols
TCP/IP
Security Protocols & Features
SSL, IPsec, 802.1x, Secure Fax
Operating System Support
MS Windows XP, MS Windows Server 2003, Apple Mac OS X 10.5, MS Windows 7, MS Windows Vista, MS Windows Server 2008
Software Included
ScanSoft PaperPort, ScanSoft OmniPage, Nuance Image Retriever
425 Watt
Power Consumption Standby
65 Watt
Power Consumption Sleep
18.4 Watt
Warm Up Time
31 sec
First Copy Out Time B/W
13 sec
First Copy Out Time Colour
20 sec
Phone cable
Consumables Included
1 x Cartridge ( black ) - up to 1000 pages , 1 x Cartridge ( cyan ) - up to 1000 pages , 1 x Cartridge ( magenta ) - up to 1000 pages , 1 x Cartridge ( yellow ) - up to 1000 pages
GOST, GS, NOM, FCC Part 15 B, EMC, R&TTE, UL 60950-1, CSA C22.2 No. 60950-1-07, Section 508
EPEAT Compliant
EPEAT Silver
Limited warranty - 1 year - on-site
43 cm
54.4 cm
58.4 cm
29.6 kg
Sound Emission
22 dBA (idle) / 52 dBA (operating)
10 °C
32 °C
10 - 85% (non-condensing)
Scroll to top
