BT.com
Wishlist
Xerox WorkCentre 6027V_NI Colour Laser Multifunction Printer
Xerox WorkCentre 6027V_NI Colour...
£301.70
£301.70
Add to wishlist
Delivery
Standard Due date unavailable
The compact WorkCentre 6027 Color Multifunction Printer excels in small office environments where high-impact color, speed, Wi-Fi connectivity and ease of use are priorities. With efficient print, copy, scan, fax and email functions on one device, you can get your work done quickly, without a second thought.
Xerox WorkCentre 6027V_NI - multifunction printer (colour)
Fax / copier / printer / scanner
Fax Type
Super G3 - plain paper
Printing Technology
LED (colour)
Monthly Duty Cycle (max)
30000 pages
Recommended Monthly Volume
1500 pages
Max Copying Speed
Up to 18 ppm (mono) / up to 18 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Up to 1200 x 2400 dpi (mono) / up to 1200 x 2400 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
MH, MR, MMR, JBIG
Fax Resolutions
203 x 98 dpi, 203 x 196 dpi, 203 x 392 dpi, 406 x 392 dpi
Scanning
600 x 600 dpi
Display
4.3"
Original Size
Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
15 sheets
Media Size
76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, labels, recycled paper, bond paper, card stock, light-weight paper, glossy paper
Standard Media Capacity
150 sheets
Output Trays Capacity
100 sheets
PC Connection Availability
PC Connection
USB 2.0, LAN, Wi-Fi(n), USB host
AirPrint Enabled
Office Machine Features
Save to USB flash drive, scan to e-mail, scan to network, Google Cloud Print ready
AC 230 V (50/60Hz)
41 cm x 43.9 cm x 38.8 cm
16.9 kg
Environmental Standards
ENERGY STAR Qualified, Blue Angel
1 year warranty
Fax Type
Plain paper
Printing Technology
LED - colour
30000 pages
1500 pages
Display Diagonal Size
4.3"
Display Features
Touch screen
PC Connection
AirPrint Enabled
Standard Memory
512 MB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Copying Features
Fit to page, ID Card Copy, collation copy, Edge Erase
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c, PDF, TIFF
First Print Out Time B/W
12 sec
First Print Out Time Colour
13 sec
Colour Management Features
PANTONE Digital Color
Scanning
Optical Resolution
600 x 600 dpi
Grey Scale Depth
8 bit
Colour Depth
24 bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
MH, MR, MMR, JBIG
Fax Resolutions
Fax Machine Features
One Touch Dialing
8 station(s)
Delayed Transmission
Fax forwarding, automatic redialing, group dialling, auto reduction
Document & Media Handling
Max Original Size
Original Type
Sheets
15 sheets
Min Media Size
76 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
163 g/m²
Supported Media Type
Supported Media Sizes
150 sheets
100 sheets
ADF - 15 sheets size: A5 (148 x 210 mm) - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m² weight (lbs): , Input tray - 150 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² weight (lbs): , Output tray - 100 sheets weight (lbs):
Speed Details
Printing: up to 18 ppm (A4) - B/W , Printing: up to 18 ppm (A4) - colour , Copying: up to 18 ppm (A4) - B/W , Copying: up to 18 ppm (A4) - colour , Scanning: up to 14 ipm (A4) - B/W , Scanning: up to 9 ipm (A4) - colour
1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x LAN - RJ-45
Security Protocols & Features
SSL, WEP, WPA, WPA2, IPsec, WPA2-PSK, WPS, IP filtering, Wi-Fi Direct, TTLS
Operating System Support
Apple Mac OS X 10.6.x, Apple Mac OS X 10.5.8, Apple Mac OS X 10.7.x, MS Windows Server 2008 R2 x64 Edition, Ubuntu Linux 12.04, Apple Mac OS X 10.8.x, Windows 8, Windows 8 64-bit, MS Windows Server 2012 x64 Edition, Red Hat Enterprise Linux 6 Desktop, Windows 8.1, Windows 8.1 64-bit, MS Windows Server 2003 (32/64-bits), MS Windows Server 2008 (32/64-bits), MS Windows Server 2012 R2 x64 Edition, Apple Mac OS X 10.9.x, MS Windows XP (32/64 bits), MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), SUSE Linux Enterprise Desktop 11 (32/64-bit)
AC 230 V (50/60Hz)
330 Watt
Power Consumption Standby
45 Watt
Power Consumption Sleep
3.5 Watt
First Copy Out Time B/W
20 sec
First Copy Out Time Colour
30 sec
USB cable
Consumables Included
1 x Cartridge (black) - up to 500 pages , 1 x Cartridge (cyan) - up to 500 pages , 1 x Cartridge (magenta) - up to 500 pages , 1 x Cartridge (yellow) - up to 500 pages
EN55024, EN55022 Class B, EN 60950-1 Second Edition, Directive 2012/19/EU, Directive 2011/65/EU, EMC 2004/108/EC, LVD 2006/95/EC, IEC 60950-1:2005 Second Edition
Blue Angel Compliant
Limited warranty - 1 year - on-site
41 cm
43.9 cm
38.8 cm
16.9 kg
Shipping Width
56.7 cm
Shipping Depth
54.1 cm
Shipping Height
53.3 cm
Shipping Weight
19.9 kg
Sound Emission
21.9 dBA (idle) / 49.1 dBA (operating)
10 °C
32 °C
10 - 85%
Scroll to top
