BT.com
Wishlist
Xerox WorkCentre 3615DN A4 Mono USB Laser Multifunction Printer
Xerox WorkCentre 3615DN A4 Mono USB...
£596.59
£596.59
Add to wishlist
Delivery
Standard Due date unavailable
The WorkCentre 3615 multifunction printer offers a full productivity toolbox in one device, so you're more efficient every day.
Productivity and Paper Handling
- A 60-sheet Duplex Automatic Document Feeder scans two-sided originals for copy, scan and fax jobs.
- The WorkCentre 3615 includes a 109 mm (4.3-inch) colour touch screen with easily understood instructions and help screens to streamline walkup operations.
- An easily accessible USB port allows users to quickly print from or scan to any standard USB memory device.
- 250-sheet output tray with tray-full sensor.
- 150-sheet Multipurpose Tray handles media sizes from 76 x 127 mm to 216 x 356 mm (3 x 5 in. to 8.5 x 14 in.).
- With the 550-sheet paper tray, standard paper capacity for the WorkCentre 3615 totals 700 sheets.
- Up to three optional 550-sheet paper trays increase total paper capacity to 2,350 sheets.
- Optional stand provides storage for toner cartridges, paper and other supplies.
- Place the WorkCentre 3615 anywhere you need it with the optional Wi-Fi Network Adapter.
Speed, Scanning and Print Quality
With best-in-class speed*, print resolution and media capacity, your busy office can deliver professional-looking prints, without waiting.
Built for speed.
Print up to 45 pages per minute (ppm) - the fastest monochrome print speed in its class*. Your first page prints in as few as 6.5 seconds.
True multifunction capability.
The intuitive 109 mm (4.3-inch) colour touch screen on the WorkCentre 3615 lets you program your next job while another is in progress.
Digitize...and simplify.
Easily turn cumbersome hard copy forms and documents into portable, digital files. Enjoy the added convenience of sharing your digital files automatically via email. You can even send your files to an established network folder or export them to any USB memory device.
Crisp details.
Bring definition and clarity to your documents with true print resolution of up to 1200 x 1200 dpi. Your printed communications never looked better.
* When compared to similar products as of September 2013.
Powerful Capabilities Built for Savings
Advanced tools improve security and save paper, power and time.
Reduce paper usage.
You'll dramatically lower your paper usage and related costs thanks to automatic two-sided printing. Plus, N-up printing enables you to print multiple pages on one sheet - a useful option when sharing presentations.
Increase efficiency.
Extra-high capacity toner cartridges allow you spend less time loading supplies and more time getting work done.
Keep information safe.
Secure Print keeps your sensitive documents out of the wrong hands by requiring users to enter a personal identification number at the device to print documents.
Use less power.
Unique Xerox® EA Toner fuses at a much lower temperature, reducing power consumption by up to 20% and CO2 emissions by up to 35%, compared to conventional toner.
All-in-one savings.
The WorkCentre 3615 combines the functions of a copier, printer, scanner and fax machine into a single, value-packed unit that can generate savings on energy and supplies costs.
Work From Anywhere.
When you're on the go, you can still print to the WorkCentre 3615, and manage it remotely from a web browser.
Print when and where you want.
With Apple® AirPrint™, you can print email, and important office documents, directly from your mobile iOS device when connected to your office Wi-Fi network.
And when working offsite, you can rely on Xerox® PrintBack to print documents back at the office so they are waiting for you when you return.
Freedom, unplugged.
With optional Wi-Fi capabilities, the WorkCentre 3615 is ready to go to work wherever it's needed.
Manage from a web browser.
Handle device administration remotely from any networked computer with Xerox® CentreWare® IS.
Xerox WorkCentre 3615/DN - multifunction printer (B/W)
Fax / copier / printer / scanner
Fax Type
Super G3 - plain paper
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
110000 pages
Recommended Monthly Volume
12000 pages
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 45 ppm
Max Printing Resolution
Up to 1200 x 1200 dpi
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
MH, MR, MMR, JBIG
Fax Resolutions
203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi, 400 x 400 dpi
Scanning
1200 x 1200 dpi
Original Size
Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
60 sheets
Media Size
76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, labels, heavy-weight paper, thick paper, card stock, light-weight paper
Standard Media Capacity
700 sheets
Max Media Capacity
2350 sheets
Bypass Feeder Capacity
150 sheets
Output Trays Capacity
250 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
PC Connection Availability
PC Connection
USB 2.0, LAN, USB host
Office Machine Features
Save to USB flash drive, scan to e-mail
(50/60Hz)
49.5 cm x 49.2 cm x 54.9 cm
21.5 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified, Blue Angel, EPEAT Silver
Fax Type
Plain paper
Printing Technology
Laser - monochrome
110000 pages
12000 pages
PC Connection
Standard Memory
1 GB
Copying
Up to 600 x 600 dpi
Automatic Duplexing
Copying Features
Fit to page, ID Card Copy, Job Build, Edge Erase, photo mode
Printing
Max Printing Speed
Up to 45 ppm
Printer Drivers / Emulations
PCL 5e, PCL 6, PostScript 3, PDF
Automatic Duplexing
First Print Out Time B/W
6.5 sec
Scanning
Automatic Duplexing
Optical Resolution
1200 x 1200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
MH, MR, MMR, JBIG
Fax Resolutions
Fax Machine Features
Speed Dialing
200 station(s)
Broadcast Transmission
200 stations
Fax forwarding, Distinctive Ring Pattern Detection (DRPD), e-mail function, colour faxing, junk fax barrier, group dialling
Document & Media Handling
Max Original Size
Original Type
Sheets
60 sheets
Min Media Size
76 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
216 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), 76 x 127 mm, fanfold A5 (148 x 210 mm)
700 sheets
Max Media Capacity
2350 sheets
150 sheets
250 sheets
ADF - 60 sheets size: 140 x 140 mm - Legal (216 x 356 mm) weight: 50 g/m² - 125 g/m² , Bypass tray - 60 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 216 g/m² , Input tray - 550 sheets size: 148 x 210 mm - Legal (216 x 356 mm) weight: 60 g/m² - 216 g/m² , Output tray - 250 sheets
Speed Details
Printing: up to 47 ppm (Letter A) - B/W , Printing: up to 45 ppm (A4) - B/W , Printing: up to 38 ppm (Legal) - B/W , Printing: up to 29 ppm (Letter A) - B/W duplex , Printing: up to 28 ppm (A4) - B/W duplex , Printing: up to 25 ppm (Legal) - B/W duplex , Copying: up to 42 ppm (Letter A) - B/W , Copying: up to 40 ppm (A4) - B/W , Scanning: up to 40 ipm
1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x LAN - RJ-45
Security Protocols & Features
LDAP, SSL, IPsec, 802.1x, IP filtering
Operating System Support
MS Windows Server 2003, Sun Solaris 9, MS Windows 7, MS Windows XP SP1, openSUSE 11.0, MS Windows Vista, HP-UX 11.0, Red Hat Enterprise Linux 4, Sun Solaris 10, Ubuntu Linux, HP-UX 11i, MS Windows Server 2008, IBM AIX 5, MS Windows XP or later, Apple Mac OS X 10.5 or later, Red Hat Enterprise Linux 5, openSUSE 12, Red Hat Fedora Core 11-14, Red Hat Fedora Core 14-16
Software Included
Drivers & Utilities
(50/60Hz)
698 Watt
Power Consumption Standby
59 Watt
Power Consumption Sleep
4 Watt
Warm-Up Time
20 sec
First Copy Out Time B/W
8.5 sec
Phone cable
Consumables Included
1 x Cartridge (black) - up to 5900 pages , 1 x drum
CSA, EN55022 Class B, EMC, ICES-003 Class A, RoHS, UL 60950-1, EN 60950-1, WEEE, FCC Part 15 A, FDA, EN 60825-1
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
Blue Angel Compliant
49.5 cm
49.2 cm
54.9 cm
21.5 kg
Shipping Width
62.6 cm
Shipping Depth
61.8 cm
Shipping Height
70.3 cm
Shipping Weight
26.6 kg
Sound Emission
30 dBA (idle) / 56 dBA (operating)
15 °C
28 °C
20 - 70%
Accessories
£4.95
£3.84
£11.41
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.16
£51.70
Scroll to top
