BT.com
Wishlist
Xerox WorkCentre 3325V_DNI Mono Laser Multifunction Printer
Xerox WorkCentre 3325V_DNI Mono...
£387.57
£387.57
Add to wishlist
Delivery
Standard Due date unavailable
The WorkCentre 3325 monochrome all-in-one printers' small footprint makes these products a good fit for any home office or small business.
Xerox WorkCentre 3325V_DNI - multifunction printer (B/W)
Fax / copier / printer / scanner
Copier Type
Digital
Fax Type
Super G3 - plain paper
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
80000 impressions
Recommended Monthly Volume
6000 pages
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 35 ppm
Max Printing Resolution
Up to 1200 x 1200 dpi
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
MH, MR, MMR, JBIG, JPEG
Fax Resolutions
300 x 300 dpi
Original Size
142 x 148 mm (min) - Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, cards, labels, recycled paper, thin paper, thick paper
Standard Media Capacity
300 sheets
Bypass Feeder Capacity
50 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
PC Connection Availability
PC Connection
USB 2.0, Gigabit LAN, USB host, Wi-Fi
Office Machine Features
Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to folder, scan to network
46.9 cm x 45.8 cm x 44.7 cm
16.6 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified, Blue Angel
1 year warranty
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
Laser - monochrome
80000 impressions
6000 pages
PC Connection
Standard Memory
256 MB
Max Supported Memory
768 MB
Hard Disk Drive
2 GB
Copying
Up to 600 x 600 dpi
Automatic Duplexing
Copying Features
Booklet creation, ID Card Copy, Poster Copy
Printing
Max Printing Speed
Up to 35 ppm
Printer Drivers / Emulations
PCL 5e, PCL 6, PostScript 3, PDF, XPS
Automatic Duplexing
First Print Out Time B/W
6.5 sec
Scanning
Automatic Duplexing
Interpolated Resolution
4800 x 4800 dpi
Grey Scale Depth
8 bit
Colour Depth
24 bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Fax Resolutions
300 x 300 dpi
PC Faxing
Fax Machine Features
Speed Dialing
200 station(s)
Delayed Transmission
Fax forwarding, automatic redialing, e-mail function, colour faxing, group dialling, auto reduction
Document & Media Handling
Min Original Size
142 x 148 mm
Max Original Size
Original Type
Sheets
50 sheets
Min Media Size
76 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Supported Media Sizes
300 sheets
50 sheets
150 sheets
ADF - 50 sheets size: 142 x 148 mm - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m² , Bypass tray - 50 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , Input tray - 250 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , Output tray - 150 sheets
Speed Details
Printing: up to 35 ppm (A4) - B/W
1 x USB 2.0 , 1 x USB host , 1 x Gigabit LAN
Network Protocols
SNMP, HTTPS, Bonjour
Security Protocols & Features
LDAP, Secure Print, SSL, Apple Bonjour, IPsec, 802.1x, IP filtering, MAC address filtering
Operating System Support
MS Windows XP, SuSe Linux, HP-UX, MS Windows Server 2003, MS Windows Vista, Red Hat Enterprise Linux 4, MS Windows Server 2008, IBM AIX 5, Apple Mac OS X 10.5 or later, Oracle Solaris 10, Oracle Solaris 9
600 Watt
Power Consumption Standby
50 Watt
Power Consumption Sleep
8 Watt
Warm Up Time
35 sec
First Copy Out Time B/W
10 sec
Consumables Included
1 x Cartridge (black)
Supported Windows 7 Features
Windows HD Imaging
GOST, GS, NOM, Directive 1999/5/EC, FCC Part 68, UL 60950-1, CSA C22.2 No. 60950-1-07
Blue Angel Compliant
Limited warranty - 1 year
46.9 cm
45.8 cm
44.7 cm
16.6 kg
Sound Emission
26 dBA (idle) / 53 dBA (operating)
10 °C
32 °C
20 - 80% (non-condensing)
Accessories
£5.24
£3.94
£13.02
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£9.30
£59.01
Resources
The following resources are available for the Xerox WorkCentre 3325V_DNI Mono Laser Multifunction Printer
Scroll to top
