BT.com
Wishlist
Xerox WorkCentre 3225V_DNI Mono LED Laser Multi-Function Printer
Xerox WorkCentre 3225V_DNI Mono LED...
£206.16
£206.16
Add to wishlist
Delivery
Standard Due date unavailable
The Xerox WorkCentre 3225 consolidates five key office functions – print, copy, scan, fax and email -- into one easy-to-use multifunction laser printer. Automatic two-sided printing and built-in Wi-Fi offer individual users and small work teams powerful tools at an affordable price.
Xerox WorkCentre 3225V_DNI - multifunction printer (B/W)
Fax / copier / printer / scanner
Fax Type
Plain paper
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
30000 pages
Max Copying Resolution
Up to 1200 x 1200 dpi
Max Printing Speed
Up to 29 ppm
Max Printing Resolution
Up to 4800 x 600 dpi
Data Compression System
MH, MR, MMR, JBIG, JPEG
Scanning
600 x 600 dpi
Original Size
148 x 148 mm (min) - Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
40 sheets
Media Size
76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, labels, recycled paper, bond paper, thick paper, card stock
Standard Media Capacity
250 sheets
Bypass Feeder Capacity
1 sheet
Output Trays Capacity
120 sheets
Automatic Duplexing
Yes (printing)
PC Connection Availability
PC Connection
USB 2.0, LAN, Wi-Fi(n)
AirPrint Enabled
Office Machine Features
Scan to e-mail, scan to folder
AC 230 V (50/60Hz)
40.1 cm x 36.2 cm x 36.5 cm
11.4 kg
Environmental Standards
ENERGY STAR Qualified, Blue Angel
Fax Type
Plain paper
Printing Technology
Laser - monochrome
30000 pages
PC Connection
AirPrint Enabled
Standard Memory
256 MB
Copying
Printing
Max Printing Speed
Up to 29 ppm
Printer Drivers / Emulations
PCL 5e, PCL 6, PostScript 3
Automatic Duplexing
First Print Out Time B/W
8.5 sec
Scanning
Optical Resolution
600 x 600 dpi
Grey Scale Depth
8 bit
Fax Machine
Fax Machine Features
Fax forwarding, automatic redialing, colour faxing, auto reduction, junk fax filter, secure receive
Document & Media Handling
Min Original Size
148 x 148 mm
Max Original Size
Original Type
Sheets
40 sheets
Min Media Size
76 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm)
250 sheets
1 sheet
120 sheets
ADF - 40 sheets size: 148 x 148 mm - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m² weight (lbs): , Bypass tray - 1 sheet size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² weight (lbs): , Input tray - 250 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² weight (lbs): , Output tray - 120 sheets weight (lbs):
Speed Details
Printing: up to 29 ppm (Letter A) - B/W , Printing: up to 28 ppm (A4) - B/W
1 x USB 2.0 , 1 x LAN
Security Protocols & Features
LDAP, SSL, WPA2, IPsec, 802.1x, MAC address filtering, WPA2-Enterprise
Operating System Support
HP-UX 11i v3, SunSoft Solaris x86 9, SuSE Linux Enterprise Desktop 10, SuSE Linux Enterprise Desktop 11, openSUSE 11.0, HP-UX 11.0, HP-UX 11i v2, SunSoft Solaris x86 10, Ubuntu Linux 10.04, MS Windows Server 2008 R2, Fedora 11, Fedora 12, Fedora 13, Fedora 14, Debian Linux 5.0, Red Hat Enterprise Linux 5, HP-UX 11i v1, Red Hat Enterprise Linux 6, Fedora 15, MS Windows Server 2008 R2 x64 Edition, SunSoft Solaris x86 11, MS Windows Server 2012, Windows 8, SunSoft Solaris SPARC Platform Edition 9, SunSoft Solaris SPARC Platform Edition 10, SunSoft Solaris SPARC Platform Edition 11, Windows 8 64-bit, Fedora 16, Fedora 17, Fedora 18, openSUSE 12.3, Linux Mint 13, Linux Mint 14, MS Windows Server 2003 (32/64-bits), MS Windows Server 2008 (32/64-bits), Apple Mac OS X 10.5 - 10.9, IBM AIX 5.1 - 7.1, Fedora 19, MS Windows XP (32/64 bits), MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), Ubuntu Linux 13.04, Debian Linux 7.1, Linux Mint 15
Software Included
Nuance Image Retriever, Nuance PaperPort
AC 230 V (50/60Hz)
417 Watt
Power Consumption Standby
46 Watt
Power Consumption Sleep
2 Watt
Warm Up Time
14 sec
First Copy Out Time B/W
10 sec
Consumables Included
1 x Cartridge (black) - up to 1500 pages , 1 x drum - up to 10000 pages
GS, EN55024, EN55022 Class B, ICES-003 Class B, FCC Part 15 B, RoHS, UL 60950-1, CSA C22.2 No. 60950-1-07, WEEE, FDA, EN 60825-1, Directive 2004/108/EC, EN 60950-1 Second Edition, Directive 2006/95/EC, Directive 2012/19/EU, Directive 2011/65/EU
Blue Angel Compliant
40.1 cm
36.2 cm
36.5 cm
11.4 kg
Sound Emission
26 dBA (idle) / 53 dBA (operating)
10 °C
32 °C
20 - 80%
Accessories
£4.95
£3.76
£11.54
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.26
C2G TruLink Media Gateway RJ45 Cap
Quicklinx: 8Q37 | In Stock
£0.64
£52.29
Scroll to top
