BT.com
Wishlist
Xerox VersaLink B405DN Duplex A4 Multifunction Printer
Xerox VersaLink B405DN Duplex A4...
£625.04
12 in stock
£625.04
Add to wishlist
Delivery
Standard 1-3 working days
Marketing description is not available.
Xerox VersaLink B405V/DN - multifunction printer (colour)
Fax / copier / printer / scanner
Fax Type
Super G3 - plain paper
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
110000 pages
Recommended Monthly Volume
12000 pages
Max Copying Speed
Up to 36 ppm (mono) / up to 36 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Up to 45 ppm (mono) / up to 45 ppm (colour)
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
MH, MR, MMR, JBIG
Fax Resolutions
600 x 600 dpi
Scanning
600 x 600 dpi
Original Size
76.2 x 127 mm (min) - Legal (216 x 356 mm) (max)
Document Feeder Capacity
60 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, labels, recycled paper, bond paper, card stock, punched paper, preprinted paper
Standard Media Capacity
700 sheets
Max Media Capacity
1250 sheets
Output Trays Capacity
250 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
PC Connection Availability
PC Connection
Gigabit LAN, NFC, USB 3.0
AirPrint Enabled
Office Machine Features
Scan to e-mail, scan to network, scan to USB host
AC 230 V (50/60Hz)
49.5 cm x 49.5 cm x 55.1 cm
22 kg
Fax Type
Plain paper
Printing Technology
Laser - colour
110000 pages
12000 pages
PC Connection
AirPrint Enabled
Standard Memory
2 GB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Automatic Duplexing
Copying Features
ID Card Copy, Edge Erase, Book Copy
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 5e, PCL 6, PostScript 3, PDF, TIFF, HPGL, JPEG
Automatic Duplexing
First Print Out Time B/W
8 sec
Scanning
Automatic Duplexing
Optical Resolution
600 x 600 dpi
Grey Scale Depth
8 bit
Colour Depth
24 bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
MH, MR, MMR, JBIG
Fax Resolutions
600 x 600 dpi
Document & Media Handling
Min Original Size
76.2 x 127 mm
Max Original Size
60 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm)
700 sheets
Max Media Capacity
1250 sheets
250 sheets
RADF - 60 sheets size: 139.7 x 139.7 mm - Legal (216 x 356 mm) weight: 60 g/m² - 125 g/m² , Bypass tray - 150 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , Output tray - 250 sheets , Input tray - 550 sheets size: 148 x 210 mm - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m²
Speed Details
Printing: up to 45 ppm (Letter A) - B/W , Printing: up to 45 ppm (A4) - B/W
Security Protocols & Features
Secure Print, TLS, Secure Fax, Secure Scan, Secure Email
Software Included
Xerox CentreWare Web
AC 230 V (50/60Hz)
620 Watt
Power Consumption Standby
60 Watt
Power Consumption Sleep
4 Watt
First Copy Out Time B/W
8 sec
First Copy Out Time Colour
11 sec
Consumables Included
1 x Cartridge (black) - up to 5900 pages
FIPS 140-2
49.5 cm
49.5 cm
55.1 cm
22 kg
Shipping Width
61.8 cm
Shipping Depth
62.6 cm
Shipping Height
71.3 cm
Shipping Weight
27.1 kg
Sound Emission
52.3 dBA (idle) / 28.7 dBA (operating)
10 °C
32 °C
10 - 85%
Scroll to top
