BT.com
Wishlist
Xerox Travel Scanner 150
£139.02
£139.02
Add to wishlist
Delivery
Standard Due date unavailable
The Xerox Travel Scanner 150 is lightweight, smaller than a three hole punch and needs no AC outlet. Just connect the USB cable to your laptop, insert a document and you're scanning. And not just scanning, but scanning to popular and productive destinations such as email and Word, local/network/cloud storage or Microsoft SharePoint.
Xerox Travel Scanner 150 - sheetfed scanner
Sheetfed scanner - portable
Interface Type
USB 2.0
Scan Element Type
Contact Image Sensor (CIS)
Light Source
RGB LED array
Max Supported Document Size
Legal (216 x 356 mm)
Input Type
Grayscale / Color Depth
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi
Max Document Size
216 mm x 356 mm
Supported Document Type
Plain paper, business card, photo
Document Feeder Type
Manual
Duty Cycle
165 scans per day
Microsoft Windows Vista / XP / 7 / 8
29.7 cm x 5.1 cm x 3.8 cm
340 g
Environmental Standards
ENERGY STAR Qualified
Interface Type
USB 2.0
Scanner
Input Type
Grayscale Depth
Colour Depth
Optical Resolution
600 dpi
Scan Element Type
Bulb / Light Source Type
RGB LED array
Duty Cycle
165 scans per day
Scanner Speed Details
10 sec/scan - black & white - Letter - 200 dpi , 10 sec/scan - colour - Letter - 150 dpi
Scanner Features
Powered by USB port, Auto Crop, AutoLaunch Technology, Auto Straighten, auto brightness, Visioneer Acuity Technology
TWAIN, WIA
Media Handling
Max Document Size
216 mm x 356 mm
Manual
USB 2.0
1 x USB cable
ENERGY STAR Certified
Software Included
Presto! BizCard, Nuance PaperPort, Visioneer OneTouch, Nuance OmniPage, Visioneer Acuity, Nuance PDF Converter, Visioneer DriverPLUS
System Requirements Details
Windows XP/Vista/7/8 - Pentium 4 RAM 2 GB - HD 350 MB
29.7 cm
5.1 cm
3.8 cm
340 g
Scroll to top
