BT.com
Wishlist
Xerox Phaser 6500N Colour Laser Printer
Xerox Phaser 6500N Colour Laser...
£344.90
Hurry, only 1 left in stock!
£344.90
Add to wishlist
Delivery
Standard 1-3 working days
The Phaser 6500 is a fast reliable color printing perfect for your office. The right solution for today's pace of business, this printer gives your important documents a powerful, colorful boost. From arrival to disposal, the Phaser 6500 helps you meet today's environmental challenges.
A smaller footprint means you can locate the Phaser 6500 where it's most convenient. Easy installation and pre-loaded toner cartridges make this printer virtually plug-and-play. Superior performance gets your jobs out quickly, with print color and black-and-white print speeds up to 24 ppm.
Count on consistently precise print jobs with bright, true colors and superior graphics. Xerox-exclusive EA toner uses particles engineered for uniform size and shape, producing superior image detail and line definition, and text that's sharp and clear.
The Phaser 6500 is a value-packed color device that gets the job done with the rare combination of outstanding print quality, unparalleled simplicity, and day-in, day-out dependability.
Xerox Phaser 6500N - printer - colour - laser
Printer Type
Workgroup printer - laser - colour
18.2 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76 mm x 127 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 23 ppm - B/W - A4 (210 x 297 mm) , Up to 23 ppm - colour - A4 (210 x 297 mm)
Max Resolution (B&W)
600 dpi
Max Resolution (Colour)
600 dpi
USB, Gigabit LAN, USB host
400 MHz
RAM Installed (Max)
256 MB (768 MB)
Language Simulation
PostScript 3, PCL 6
Media Type
Envelopes, labels, plain paper, glossy paper, business cards
Total Media Capacity
250 sheets
Media Handling
250-sheet input tray, 1-sheet multipurpose tray
Monthly Duty Cycle (max)
40000 pages
Print server - Ethernet, Fast Ethernet, Gigabit Ethernet
Printer Features
Optional duplex, 4-bit depth colour technology
AC 230V
Linux, Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Vista, Apple MacOS X 10.5 or later, Microsoft Windows Server 2008
Microsoft Certification
Compatible with Windows 7
Environmental Standards
EPEAT Silver
1 year warranty
40.4 cm x 42.6 cm x 41.6 cm
Printer Type
Printer
Print Speed
Built-in Devices
Status LCD
Wired
600 dpi
600 dpi
PostScript Support
Standard
First Print Out Time B/W
12 sec
First Print Out Time Colour
13 sec
Language Simulation
PostScript 3, PCL 6
Colour Management Features
PANTONE Digital Color
Printer Features
Media Handling
400 MHz
RAM
RAM Installed (Max)
256 MB / 768 MB (max)
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76 mm x 127 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm)
Media Weight
60 g/m² - 216 g/m²
250 sheets
Media Feeders
1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 216 g/m² , 1 x manual - 1 sheet - Legal (216 x 356 mm) weight: 60 g/m² - 216 g/m²
Max Media Capacity
500 sheets
Output Trays Capacity
150 sheets
Duty Cycle
40000 pages
Print server
Network / Transport Protocol
TCP/IP
Remote Management Protocol
SNMP 3, HTTPS
Security Protocols & Features
SSL, IPsec, 802.1x
IEEE 802.1x
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x direct print port - USB 2.0 - 4 pin USB Type A
Consumables Included
1 x toner cartridge (black) - up to 1000 pages , 1 x toner cartridge (cyan) - up to 1000 pages , 1 x toner cartridge (magenta) - up to 1000 pages , 1 x toner cartridge (yellow) - up to 1000 pages
GOST, GS, NOM, FCC Part 15 B, EMC, R&TTE, UL 60950-1, CSA C22.2 No. 60950-1-07, Section 508
Power supply - internal
AC 230V
Frequency Required
50/60 Hz
375 Watt
Power Consumption Stand by / Sleep
55 Watt
Software Included
Xerox CentreWare IS Embedded Web Server, Xerox CentreWare Web, Xerox PrintingScout
EPEAT Compliant
EPEAT Silver
ENERGY STAR
Limited warranty - 1 year - on-site
10 °C
32 °C
10 - 85% (non-condensing)
Sound Emission (Idle)
25 dBA
Sound Emission (Operating)
53 dBA
40.4 cm
42.6 cm
41.6 cm
18.2 kg
Accessories
C2G 2m USB 2.0 A/B Cable - Black
Quicklinx: 63M8 | In Stock
£3.76
C2G 5m USB 2.0 A/B Cable - Black
Quicklinx: 63MW | In Stock
£5.41
C2G 2-Port USB 2.0 Manual Switch
Quicklinx: 6874 | In Stock
£20.64
£14.40
C2G 4-Port USB 2.0 Aluminum Hub
Quicklinx: 7BB4 | In Stock
£27.68
C2G 12m USB 2.0 A/A Active Extension Cable
Quicklinx: 7BB8 | In Stock
£18.87
C2G USB Superbooster Extender Kit
Quicklinx: 7H7B | In Stock
£37.30
£59.58
Resources
The following resources are available for the Xerox Phaser 6500N Colour Laser Printer
Scroll to top
