BT.com
Wishlist
Xerox Phaser 5550 Laser Printer
£2,392.81
Hurry, only 1 left in stock!
£2,392.81
Add to wishlist
Delivery
Standard 1-3 working days
The Xerox Phaser 5550DN laser printer means serious business for any office with diverse and high-volume print demands because it combines high productivity with low cost to own and operate. Large workgroups will get Xerox quality, reliability, and performance in a printer that can print at up to 50 ppm and hold up to 4,100 sheets.
Xerox Phaser 5550DN - printer - monochrome - laser
Printer Type
Workgroup printer - laser - monochrome
41 kg
Media Size Class
A3/Ledger
Max Media Size
A3 (297 x 420 mm), ANSI B (Ledger) (279 x 432 mm)
Min Media Size (Custom)
89 mm x 98 mm
Max Media Size (Custom)
297 mm x 432 mm
Print Speed
Up to 50 ppm - max speed - ANSI A (Letter) (216 x 279 mm) , Up to 50 ppm - max speed - A4 (210 x 297 mm)
Max Resolution (B&W)
1200 dpi
Automatic Duplexing
Parallel, USB, Gigabit LAN
500 MHz
RAM Installed (Max)
256 MB ( 1 GB )
Card Reader
Language Simulation
PCL 5E, PostScript 3, PCL 6
Media Type
Envelopes, transparencies, labels, plain paper, coated paper, business cards, heavy-weight paper, cards, bond paper, recycled paper, cover paper, plain paper tabs
Total Media Capacity
1100 sheets
Media Handling
2x 500-sheet input trays, 100-sheet multipurpose tray
Monthly Duty Cycle (max)
300000 pages
Print server - Ethernet, Fast Ethernet, Gigabit Ethernet, EtherTalk - integrated
AC 230V
Red Hat Linux 9, SunSoft Solaris 2.5.1, HP-UX 10.20 or later, SCO Unix, SunSoft Solaris 2.6 or later, Novell NetWare 5.x, IBM AIX 5.1, HP-UX 11i, Novell NetWare 4.x or later, SunSoft Solaris 9, Apple MacOS X 10.2 or later, Microsoft Windows Server 2003, Novell NetWare 6.5, SunSoft Solaris 10, SuSE Linux 9.x, HP-UX 11, SuSE Linux 10.0, Red Hat Fedora Core 5, Microsoft Windows Vista / 2000 / XP
1 year warranty
64 cm x 52.5 cm x 49.8 cm
Printer Type
Printer
Print Speed
Built-in Devices
Status LCD
Wired
1200 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
6.5 sec
Language Simulation
Fonts Included
83 x PCL , 139 x PostScript
Media Handling
500 MHz
RAM
RAM Installed (Max)
256 MB / 1 GB (max)
Slots Qty
2
Empty Slots
1
Card Reader
Card reader
Supported Flash Memory Cards
SIM card
Media Handling
Media Type
Media Size Class
A3/Ledger
Max Media Size
89 mm x 98 mm
297 mm x 432 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), A3 (297 x 420 mm), ANSI B (Ledger) (279 x 432 mm), 297 x 432 mm, 140 x 182 mm, 89 x 98 mm
Media Weight
60 g/m² - 215 g/m²
1100 sheets
Media Feeders
1 x automatic - 100 sheets - 297 x 432 mm weight: 60 g/m² - 215 g/m² , 1 x automatic - 500 sheets - 297 x 432 mm weight: 60 g/m² - 105 g/m² , 1 x automatic - 500 sheets - 297 x 432 mm weight: 60 g/m² - 215 g/m² , 2 x automatic (optional) - 500 sheets - 297 x 432 mm weight: 60 g/m² - 215 g/m² , 1 x automatic (optional) - 2000 sheets - 216 x 297 mm weight: 60 g/m² - 215 g/m² , 1 x automatic (optional) - 100 envelopes - 162 x 241 mm
Max Media Capacity
4100 sheets
Output Trays Capacity
500 sheets
Duty Cycle
300000 pages
Print server - integrated
Network / Transport Protocol
TCP/IP, IP/IPX, LPR/LPD, FTP, RAW, BOOTP, DHCP, DNS, SLP
Remote Management Protocol
SNMP 1, SNMP 2, SNMP 3, IPP, HTTP, HTTPS
Security Protocols & Features
802.1x
Expansion Bays
1 (total) / 1 (free) x internal
1 x USB 2.0 - 4 pin USB Type B , 1 x parallel - 36 PIN Centronics , 1 x Gigabit LAN - RJ-45
Consumables Included
1 x toner cartridge ( black ) - up to 35000 pages , 1 x drum - up to 60000 pages
FCC Class A certified, IEC 825-1/EN 60825-1 class 1, EN55024, EN55022 Class A, EMC, FCC Part 15, ICES-003 Class A, RoHS, Laser Class 1, UL 60950-1, EN 60950-1, CSA C22.2 No. 60950-1-03, WEEE, FDA
Power supply - internal
AC 230V
Frequency Required
50/60 Hz
900 Watt
Power Consumption Stand by / Sleep
105 Watt
Software Included
Driver, Xerox CentreWare IS Embedded Web Server, Xerox CentreWare Printer Management for Microsoft, Xerox CentreWare Printer Management for Novell, Xerox CentreWare Printer Management for UNIX, Xerox NDPS Gateway, Xerox Walk-Up Printer Driver, Xerox CentreWare Web, Xerox MaiLinX Alerts, Xerox PhaserSMART, Xerox PrintingScout, Xerox Usage Analysis Tool, Xerox Job Accounting, Xerox Installer, Xerox CentreWare for HP OpenView, Xerox CentreWare for Tivoli NetView, Xerox CentreWare for Unicenter TNG
Environmental Standards
ENERGY STAR
Limited warranty - 1 year - on-site
5 °C
32 °C
15 - 85%
Sound Emission (Idle)
22 dB
Sound Emission (Operating)
54 dB
64 cm
52.5 cm
49.8 cm
41 kg
Scroll to top
