BT.com
Wishlist
Xerox Mobile Scanner
£201.79
Hurry, only 1 left in stock!
£201.79
Add to wishlist
Delivery
Standard 1-3 working days
A truly mobile device in every sense of the word, Xerox Mobile Scanner gives you the power to take the information in your hand, right now, and share it with the world in seconds. The Xerox Mobile Scanner needs no cables or computer to operate. It talks to your PC, Android, Mac, iPhone, iPad, iPod touch, or the cloud over Wi-Fi. It lets you send your document anywhere your mobile device will take you and it is as simple as the gesture of handing someone a piece of paper.
Xerox Mobile Scanner - sheetfed scanner
Sheetfed scanner - portable
Interface Type
USB 2.0, Wi-Fi(n)
Scan Element Type
Contact Image Sensor (CIS)
Light Source
LED
Additional Functions
Scan to flash card
Max Supported Document Size
216 x 297 mm
Input Type
Optical Resolution
300 dpi
Scan Speed
10 sec / page
Supported Document Type
Plain paper, plastic card, photo
1
Microsoft Windows 7, Microsoft Windows Vista, Apple MacOS X 10.5 or later, Microsoft Windows XP SP3
7 cm x 29.3 cm x 5.1 cm
0.64 kg
Interface Type
USB 2.0, Wi-Fi(n)
Scan to flash card
216 x 297 mm
Scanner
Input Type
Optical Resolution
300 dpi
Scan Element Type
Bulb / Light Source Type
LED
Scan Speed
10 sec / page
Scanner Features
Scan to portable USB drive
Media Handling
Supported Flash Memory Cards
SDHC Memory Card
USB 2.0 - Type A , USB 2.0 - Mini-B
White calibration sheet, carrying case, cleaning sheet, 4 GB Eye-Fi card
1 x USB cable
External power adapter
Battery Installed
1
Run Time (Up To)
300 pages
Recharge Time
4 hours
Software Included
Nuance PaperPort, Nuance OmniPage, Xerox Mobile Scanner PC Connect, Xerox Mobile Scanner Mac Connect
7 cm
29.3 cm
5.1 cm
0.64 kg
Scroll to top
