BT.com
Wishlist
Xerox DocuMate 6440 A4 Colour Document Scanner
Xerox DocuMate 6440 A4 Colour...
£444.56
Hurry, only 1 left in stock!
£444.56
Add to wishlist
Delivery
Standard 1-3 working days
Information is the lifeblood of every business. In today's digital world, it's important to be able to manage paper documents and unlock business-critical data stored in documents. The Xerox DocuMate 6440 is a fast and user-friendly scanner. With its advanced paper handling technology, integrated image enhancing software and a small footprint, the DocuMate 6440 is packed with features that will change how you look at and manage paper documents and information.
Xerox DocuMate 6440 - document scanner
Document scanner - desktop
Interface Type
USB 2.0
Scan Element Type
CCD
Light Source
LED
Max Supported Document Size
241 x 2997 mm
Input Type
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi
Interpolated Resolution
1200 dpi
Max Document Scan Speed
60 ppm (mono) / 60 ppm (colour)
Max Document Size
241 mm x 2997 mm
Automatic Duplexing
Supported Document Type
Plain paper, plastic card, photo
Document Feeder Type
Automatic
Document Storage Capacity
80 sheets
Duty Cycle
6000 scans per day
Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista, Windows 8, Windows 10
31.6 cm x 16.8 cm x 19.1 cm
4.2 kg
Environmental Standards
ENERGY STAR Qualified
Interface Type
USB 2.0
241 x 2997 mm
Scanner
Input Type
Grayscale Depth (External)
Colour Depth (External)
Optical Resolution
600 dpi
1200 dpi
Automatic Duplexing
Scan Element Type
CCD
Bulb / Light Source Type
LED
Max Document Scan Speed B/W
60 ppm
Max Document Scan Speed Colour
60 ppm
Duty Cycle
6000 scans per day
Scanner Speed Details
60 ppm - black & white - 200 dpi , 60 ppm - colour - 200 dpi , 40 ppm - black & white - 300 dpi , 40 ppm - colour - 300 dpi
Scan File Formats
PDF
TWAIN, ISIS, WIA
Media Handling
Max Document Size
241 mm x 2997 mm
Supported Document Size Details
ADF - up to 241 x 2997 mm
Automatic
80 sheets
USB 2.0
1 x USB cable
Software Included
Drivers & Utilities, Nuance PaperPort, Visioneer OneTouch, Visioneer Acuity, Nuance Power PDF, Nuance OmniPage Ultimate
System Requirements Details
Windows XP/Vista/7/8/10 - Pentium 4 RAM 2 GB - HD 350 MB (USB)
31.6 cm
16.8 cm
19.1 cm
4.2 kg
Scroll to top
