BT.com
Wishlist
Xerox Documate 5460i A4 Colour Document Scanner
Xerox Documate 5460i A4 Colour...
£865.72
Hurry, only 1 left in stock!
£865.72
Add to wishlist
Delivery
Standard 1-3 working days
There is super power packed in this small scanner. Capable of scanning a variety of documents, including long, small, thick and thin sheets, the DocuMate 5460 will greatly boost the efficiency of your office. Conveniently small enough to fit on the reception desk of a medical office or bank, the scanner is designed to quickly scan customer or patient ID cards and other documents, enabling real-time information sharing to provide fast, accurate customer service.
The scanners have a convenient interface that allows the user to simply insert their document and press one button on the front panel to initiate scanning and automatically email, print, convert or share their document.
Xerox DocuMate 5460 - document scanner - desktop - USB 2.0
Document scanner - desktop
Interface Type
USB 2.0
Scan Element Type
Contact Image Sensor (CIS)
Light Source
LED
Max Supported Document Size
216 x 2540 mm
Input Type
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi
Max Document Scan Speed
60 ppm (mono) / 60 ppm (colour)
Max Document Size
216 mm x 2540 mm
Automatic Duplexing
Supported Document Type
Plain paper
Document Feeder Type
Automatic
Document Storage Capacity
75 sheets
Duty Cycle
6000 scans per day
Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista, Windows 8
31.8 cm x 28 cm x 24.1 cm
4 kg
Environmental Standards
ENERGY STAR Qualified
1 year warranty
Interface Type
USB 2.0
216 x 2540 mm
Scanner
Input Type
Grayscale Depth (External)
Colour Depth (External)
Optical Resolution
600 dpi
Automatic Duplexing
Scan Element Type
Bulb / Light Source Type
LED
Max Document Scan Speed B/W
60 ppm
Max Document Scan Speed Colour
60 ppm
Duty Cycle
6000 scans per day
Scanner Speed Details
60 ppm - black & white - A4 - 200 dpi , 60 ppm - colour - A4 - 200 dpi , 60 ppm - black & white - Letter - 200 dpi , 60 ppm - colour - Letter - 200 dpi , 120 ipm - duplex - black & white - 200 dpi , 120 ipm - duplex - colour - 200 dpi , 120 ipm - duplex - black & white - Letter - 200 dpi , 120 ipm - duplex - colour - Letter - 200 dpi
Scanner Features
Visioneer Acuity Technology
TWAIN, ISIS, WIA
Media Handling
Max Document Size
216 mm x 2540 mm
Plain paper
Supported Document Size Details
ADF - up to 216 x 2540 mm
Automatic
75 sheets
USB 2.0
1 x USB cable
ENERGY STAR Certified
External power adapter
Software Included
Drivers & Utilities, Nuance OmniPage Professional, Nuance PaperPort, Visioneer OneTouch, Visioneer Acuity, Nuance PDF Converter, Visioneer DriverPLUS
System Requirements Details
Windows XP/Vista/7/8 - Pentium 4 RAM 2 GB - HD 350 MB (USB 2.0)
31.8 cm
28 cm
24.1 cm
4 kg
Limited warranty - 1 year
Scroll to top
