BT.com
Wishlist
Xerox Documate 4799 VRS Standard Document Scanner
Xerox Documate 4799 VRS Standard...
£6,663.08
Hurry, only 1 left in stock!
£6,663.08
Add to wishlist
Delivery
Standard 1-3 working days
Versatility, high-speed and superior reliability make the Xerox DocuMate 4799 a powerful scanner for demanding environments. With up to a 40,000 page per day duty cycle, this innovative workhorse scans up to 100 pages per minute and employs three advanced sensor systems: ultrasonic double feed detection, stapled document detection and intelligent feed control to ensure that your scan job will not get interrupted.
Documents of various sizes can be stacked together in the automatic feed tray without worry because the Xerox DocuMate 4799 employs not one, but three ultrasonic double feed detection sensors to cover the entire width of a document.
The scanner has another set of sensors designed to detect staples anywhere in a document. As soon as a staple is detected, the scanning process is halted - minimizing damage to the optical glass and your documents.
A third set of sensors constantly monitors the thickness of documents being fed into the scanner and automatically adjusts the roller pressure to ensure that all pages are accurately fed. This combination of sensors creates one of the most reliable feed mechanisms available today.
The Xerox DocuMate 4799 provides both high quality image enhancement and increased productivity with Kofax VRS Professional AIPE-EBC for auto-everything scanning, including auto rotation, blank page deletion and auto color detect. VRS Professional improves your workflow and reduces the total time needed to scan even the largest volumes of mixed batch documents.
The DocuMate 4799 also employs a device-independent color space that is compatible with the Xerox iGen digital press so that you can be assured that the color fidelity of your original translates to the output of your real time digital press.
When the occasional paper jam happens, the Xerox DocuMate 4799 is very easy to maintain. Its unique "clamshell" design allows full access to the entire paper path, so you can clear paper jams or clean the unit without calling a service technician. The rollers are easy to replace, improving the unit's cost effectiveness, and have a long service life.
Xerox DocuMate 4799 - document scanner
Document scanner - desktop
Interface Type
USB 2.0
Scan Element Type
Dual CCD
Max Supported Document Size
297 x 432 mm
Input Type
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi
Max Document Scan Speed
100 ppm (mono) / 100 ppm (colour)
Max Document Size
297 mm x 432 mm
Automatic Duplexing
Supported Document Type
Plain paper
Document Feeder Type
Automatic
Document Storage Capacity
250 sheets
Duty Cycle
40000 scans per day
Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista
47.4 cm x 58.5 cm x 32.9 cm
25 kg
Environmental Standards
ENERGY STAR Qualified
Interface Type
USB 2.0
297 x 432 mm
Scanner
Input Type
Grayscale Depth (External)
Colour Depth (External)
Optical Resolution
600 dpi
Scan Mode
Single/duplex pass
Automatic Duplexing
Scan Element Type
Dual CCD
Max Document Scan Speed B/W
100 ppm
Max Document Scan Speed Colour
100 ppm
Duty Cycle
40000 scans per day
Scanner Speed Details
200 ipm - duplex - black & white - 200 dpi , 100 ppm - black & white - 200 dpi
Scanner Features
Ultrasonic Double Feed Detection, Visioneer OneTouch with Kofax VRS Technology, Ionizer, built-in LCD screen
TWAIN, ISIS, WIA
Media Handling
Max Document Size
297 mm x 432 mm
Plain paper
Supported Document Size Details
ADF - up to 297 x 432 mm
Automatic
250 sheets
USB 2.0 - Type B
1 x USB cable
ENERGY STAR Certified
External power adapter
Power Consumption Operational (Standby)
110 Watt (45 Watt)
Software Included
Kofax VirtualReScan Basic, Nuance OmniPage Professional, Visioneer OneTouch
System Requirements Details
Windows XP - Pentium 4 RAM 512 MB - HD 350 MB , Windows 7/Vista - Pentium 4 RAM 2 GB - HD 350 MB
47.4 cm
58.5 cm
32.9 cm
25 kg
15 °C
30 °C
10 - 80%
Scroll to top
