BT.com
Wishlist
Xerox Documate 4790 VRS Pro Document Scanner
Xerox Documate 4790 VRS Pro...
£3,877.47
£3,877.47
Add to wishlist
Delivery
Standard Due date unavailable
The Xerox DocuMate 4790 is the ideal scanner for both large-volume and distributed scanning environments. It has a duty cycle of up to 10,000 sheets per day and has been engineered with innovative features for easy operation and productive batch scanning, including stapled document, ultrasonic double feed detection and support for long document scanning.
The Xerox DocuMate 4790 scans up to 90 ppm and 180 ipm and includes a 200-page automatic document feeder that accepts up to A3 size documents and can handle nearly any mix of paper in various sizes and thicknesses. Its unique paper feed mechanism minimizes the possibility of damaging important documents and ensures precise feeding to make your office work even more efficient.
The scanning glass is protected by the use of various sensors that detect stapled pages and automatically interrupt the scan process. It is also equipped with ultrasonic multi-feed detection and an innovative self-cleaning function that removes dust from the scanning glass to ensure consistently high image quality.
The Xerox DocuMate 4790 has a convenient clamshell design that allows direct and straightforward access to the entire paper path, so a user can clear paper jams, clean the unit, or replace rollers easily without having to call a service technician.
The Xerox DocuMate 4790 provides both high-quality image enhancement and increased productivity with Kofax VRS Professional AIPE-EBC for auto-everything scanning, including auto rotation, blank page deletion and auto color detect. VRS Professional improves your workflow and reduces the total time required to finish even the largest batches of mixed documents.
The DocuMate 4790 is powered by Visioneer OneTouch scanning technology for simplifying scan jobs and workflows. The scanner also has an easy-to-read LCD on the front that reminds the user of the resolution, color mode, file type, processing and final destination of the scanned document. You'll find the Xerox DocuMate 4790 to be the kind of advanced and reliable equipment you expect to come from Xerox.
Xerox DocuMate 4790 - document scanner
Document scanner - desktop
Interface Type
USB 2.0
Scan Element Type
Dual CCD
Light Source
Xe-gas cold cathode fluorescent lamp
Max Supported Document Size
305 x 2540 mm
Input Type
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
90 ppm (mono) / 90 ppm (colour)
Max Document Size
297 mm x 432 mm
Automatic Duplexing
Supported Document Type
Plain paper
Document Feeder Type
Automatic
Document Storage Capacity
200 sheets
Duty Cycle
10000 scans per day
Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista
Microsoft Certification
Compatible with Windows 7
46.8 cm x 44.4 cm x 33.9 cm
18 kg
Environmental Standards
ENERGY STAR Qualified
Interface Type
USB 2.0
305 x 2540 mm
Scanner
Input Type
Grayscale Depth (External)
Colour Depth (External)
Optical Resolution
600 dpi x 600 dpi
Scan Mode
Single/duplex pass
Automatic Duplexing
Scan Element Type
Dual CCD
Bulb / Light Source Type
Max Document Scan Speed B/W
90 ppm
Max Document Scan Speed Colour
90 ppm
Duty Cycle
10000 scans per day
Scanner Speed Details
90 ppm - black & white - 200 dpi , 90 ppm - colour - 200 dpi
Scanner Features
Ultrasonic Double Feed Detection, Visioneer OneTouch with Kofax VRS Technology, Ionizer, built-in LCD screen
TWAIN, ISIS, WIA
Media Handling
Max Document Size
297 mm x 432 mm
Plain paper
Supported Document Size Details
ADF - up to 305 x 2540 mm
Automatic
200 sheets
USB 2.0 - Type B
1 x USB cable
ENERGY STAR Certified
External power adapter
Software Included
Kofax VirtualReScan Professional, Nuance OmniPage Professional, Visioneer OneTouch with Kofax VRS Technology
System Requirements Details
Windows XP - Pentium 4 RAM 512 MB - HD 350 MB , Windows 7/Vista - Pentium 4 RAM 1 GB - HD 350 MB
46.8 cm
44.4 cm
33.9 cm
18 kg
Scroll to top
