BT.com
Wishlist
Xerox DocuMate 4790 A3 Sheet-Fed Document Scanner
Xerox DocuMate 4790 A3 Sheet-Fed...
£3,602.59
£3,602.59
Add to wishlist
Delivery
Standard Due date unavailable
The Xerox DocuMate 4790 is the ideal scanner for both large-volume and distributed scanning environments. It has a duty cycle of up to 10,000 sheets per day and has been engineered with innovative features for easy operation and productive batch scanning, including stapled document, ultrasonic double feed detection and support for long document scanning.
The Xerox DocuMate 4790 scans up to 90 ppm and 180 ipm and includes a 200-page automatic document feeder that accepts up to A3 size documents and can handle nearly any mix of paper in various sizes and thicknesses. Its unique paper feed mechanism minimizes the possibility of damaging important documents and ensures precise feeding to make your office work even more efficient.
The scanning glass is protected by the use of various sensors that detect stapled pages and automatically interrupt the scan process. It is also equipped with ultrasonic multi-feed detection and an innovative self-cleaning function that removes dust from the scanning glass to ensure consistently high image quality.
The Xerox DocuMate 4790 has a convenient clamshell design that allows direct and straightforward access to the entire paper path, so a user can clear paper jams, clean the unit, or replace rollers easily without having to call a service technician.
The Xerox DocuMate 4790 provides both high-quality image enhancement and increased productivity with Kofax VRS Professional AIPE-EBC for auto-everything scanning, including auto rotation, blank page deletion and auto color detect. VRS Professional improves your workflow and reduces the total time required to finish even the largest batches of mixed documents.
The DocuMate 4790 is powered by Visioneer OneTouch scanning technology for simplifying scan jobs and workflows. The scanner also has an easy-to-read LCD on the front that reminds the user of the resolution, color mode, file type, processing and final destination of the scanned document. You'll find the Xerox DocuMate 4790 to be the kind of advanced and reliable equipment you expect to come from Xerox.
Xerox DocuMate 4790 - document scanner - desktop - USB 2.0
Document scanner - desktop
Interface Type
USB 2.0
Scan Element Type
Dual CCD
Max Supported Document Size
A3 (297 x 420 mm)
Input Type
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi
Max Document Scan Speed
90 ppm (mono) / 90 ppm (colour)
Max Document Size
305 mm x 2540 mm
Automatic Duplexing
Supported Document Type
Plain paper
Document Feeder Type
Automatic
Document Storage Capacity
200 sheets
Duty Cycle
15000 scans per day
Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista
Microsoft Certification
Compatible with Windows 7
46.8 cm x 44.4 cm x 33.9 cm
18 kg
Environmental Standards
ENERGY STAR Qualified
1 year warranty
Interface Type
USB 2.0
A3 (297 x 420 mm)
Scanner
Input Type
Grayscale Depth (External)
Colour Depth (External)
Optical Resolution
600 dpi
Scan Mode
Single/duplex pass
Automatic Duplexing
Scan Element Type
Dual CCD
Max Document Scan Speed B/W
90 ppm
Max Document Scan Speed Colour
90 ppm
Duty Cycle
15000 scans per day
Scanner Speed Details
90 ppm - black & white - A4 / Letter - 200 dpi , 90 ppm - colour - A4 / Letter - 200 dpi , 70 ppm - black & white - A4 / Letter - 300 dpi , 70 ppm - colour - A4 / Letter - 300 dpi
Scanner Features
Ultrasonic Double Feed Detection, Visioneer OneTouch with Kofax VRS Technology, Ionizer, built-in LCD screen, stapled document detection
TWAIN, ISIS, WIA
Media Handling
Max Document Size
305 mm x 2540 mm
Plain paper
Supported Document Size Details
ADF - up to 305 x 2540 mm
Automatic
200 sheets
USB 2.0 - Type B
Roller cleaning paper, shading paper, cleaning paper, blower brush, shading caution leaflet, DFP roller pad
1 x USB cable
ENERGY STAR Certified
External power adapter
Power Consumption Operational (Standby)
110 Watt (45 Watt)
Software Included
Nuance OmniPage Professional, Visioneer OneTouch with Kofax VRS Technology, Kofax VRS Basic
System Requirements Details
Windows XP - Pentium 4 RAM 512 MB - HD 350 MB , Windows 7/Vista - Pentium 4 RAM 1 GB - HD 350 MB
46.8 cm
44.4 cm
33.9 cm
18 kg
Limited warranty - 1 year , Technical support - phone consulting , Technical support - web support
15 °C
30 °C
20 - 80%
Scroll to top
