BT.com
Wishlist
Xerox DocuMate 4760 Scanner
£2,091.43
£2,091.43
Add to wishlist
Delivery
Standard Due date unavailable
The Xerox DocuMate 4760 delivers high-quality production scanning to any organization, at an affordable price. With its powerful combination of image quality, easy to use features and fast scanning speeds, it is the perfect solution for businesses looking to achieve high levels of flexibility within a low volume production scanning environment. The DocuMate 4760 scans documents at 60 ppm (simplex) and 120 ipm (duplex) at 300 dpi in color, grayscale, and black & white modes. It also includes a 150-page capacity Automatic Document Feeder (ADF), has the ability to scan a wide range of mixed document sizes (up to A3 / 11" x 17") and supports long document scanning up to 38" (965 mm).
Xerox DocuMate 4760 - document scanner
Document scanner - desktop
Interface Type
USB 2.0
Scan Element Type
Dual CCD
Max Supported Document Size
A3 (297 x 420 mm)
Input Type
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi
Max Document Scan Speed
60 ppm (mono) / 60 ppm (colour)
Max Document Size
297 mm x 965 mm
Automatic Duplexing
Supported Document Type
Plain paper
Document Feeder Type
Automatic
Document Storage Capacity
150 sheets
Duty Cycle
5000 scans per day
Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista
42.7 cm x 27.7 cm x 21.8 cm
9 kg
Environmental Standards
ENERGY STAR Qualified
1 year warranty
Interface Type
USB 2.0
A3 (297 x 420 mm)
Scanner
Input Type
Grayscale Depth (External)
Colour Depth (External)
Optical Resolution
600 dpi
Scan Mode
Single/duplex pass
Automatic Duplexing
Scan Element Type
Dual CCD
Max Document Scan Speed B/W
60 ppm
Max Document Scan Speed Colour
60 ppm
Duty Cycle
5000 scans per day
Scanner Speed Details
60 ppm - black & white - 200 dpi , 120 ipm - duplex - black & white - 200 dpi , 60 ppm - colour - 150 dpi , 120 ipm - duplex - colour - 150 dpi
Scanner Features
Ultrasonic Double Feed Detection, Visioneer OneTouch with Kofax VRS Technology
TWAIN, ISIS, WIA
Media Handling
Max Document Size
297 mm x 965 mm
Plain paper
Supported Document Size Details
ADF - up to 297 x 965 mm
Automatic
150 sheets
USB 2.0 - Type B
1 x USB cable
External power adapter
Power Consumption Operational (Standby)
39.5 Watt (11.4 Watt)
Software Included
Kofax VirtualReScan Basic, Nuance OmniPage Professional, Visioneer OneTouch with Kofax VRS Technology
System Requirements Details
Windows XP SP2 - Pentium 4 RAM 1 GB - HD 350 MB , Windows 7/Vista - Pentium 4 RAM 2 GB - HD 350 MB
42.7 cm
27.7 cm
21.8 cm
9 kg
Limited warranty - 1 year , Technical support - web support - 1 year , Technical support - phone consulting - 1 year
Scroll to top
