BT.com
Wishlist
Xerox Documate 4440i A4 Document Scanner
Xerox Documate 4440i A4 Document...
£574.30
£574.30
Add to wishlist
Delivery
Standard 1-3 working days
The DocuMate 4440 is a fast and easy to use scanner that enables users with an effective way to greatly reduce paper chaos, storage requirements, and security risks associated with unorganized paperwork at home or the office. The DocuMate 4440 is packed with features that will change how you look at and manage paper documents and information.
Xerox DocuMate 4440 - document scanner - desktop - USB 2.0
Document scanner - desktop
Interface Type
USB 2.0
Scan Element Type
Dual CCD
Light Source
White LED
Max Supported Document Size
216 x 2997 mm
Input Type
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
40 ppm (mono) / 40 ppm (colour)
Max Document Size
216 mm x 2997 mm
Automatic Duplexing
Supported Document Type
Plain paper, plastic card
Document Feeder Type
Automatic
Document Storage Capacity
50 sheets
Duty Cycle
5000 scans per day
Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista, Windows 8
Microsoft Certification
Compatible with Windows 7
30.5 cm x 52.8 cm x 35.2 cm
3.85 kg
Interface Type
USB 2.0
216 x 2997 mm
Scanner
Input Type
Grayscale Depth (External)
Colour Depth (External)
Optical Resolution
600 dpi x 600 dpi
Automatic Duplexing
Scan Element Type
Dual CCD
Bulb / Light Source Type
White LED
Max Document Scan Speed B/W
40 ppm
Max Document Scan Speed Colour
40 ppm
Duty Cycle
5000 scans per day
Scanner Speed Details
80 ipm - duplex - black & white - 200 dpi , 80 ipm - duplex - colour - 150 dpi , 40 ppm - black & white - 200 dpi , 40 ppm - colour - 150 dpi , 30 ppm - black & white - 300 dpi , 30 ppm - colour - 300 dpi , 30 ppm - greyscale - 300 dpi , 60 ipm - duplex - colour - 300 dpi , 60 ipm - duplex - black & white - 300 dpi , 60 ipm - duplex - greyscale - 300 dpi
TWAIN, ISIS, WIA
Media Handling
Max Document Size
216 mm x 2997 mm
Supported Document Size Details
ADF - up to 216 x 2997 mm
Automatic
50 sheets
USB 2.0 - Type B
1 x USB cable
External power adapter
Software Included
Kofax VirtualReScan, Nuance OmniPage Professional, Nuance PaperPort, Visioneer OneTouch, Visioneer Acuity, Nuance PDF Converter
System Requirements Details
Windows XP - Pentium 4 RAM 512 MB - HD 350 MB (USB) , Windows Vista/7/8 - Pentium 4 RAM 1 GB - HD 350 MB (USB)
30.5 cm
52.8 cm
35.2 cm
3.85 kg
Scroll to top
