BT.com
Wishlist
Xerox DocuMate 3920 Document Scanner
Xerox DocuMate 3920 Document...
£520.34
Hurry, only 1 left in stock!
£520.34
Add to wishlist
Delivery
Standard 1-3 working days
Direct connect scanners are a vital part of your document capture strategy, but network scanners, like the DocuMate 3920, are the perfect solution for an office that has shared scanner needs. Network accessible scanning achieves two major goals for your document workflow and capture with great efficiency and ease of use. First, a network scanner can be conveniently located in common areas and does not require a PC connection. Second, the scanner can easily access broad network connections to file servers, email servers, FTP locations and printers and fax servers. The DocuMate 3920 is designed with convenience and ease to support small to medium workgroups and offices through a standard Ethernet connection and provides a secure multi-user access, with easy administration, through an embedded form-based web page configuration. No expensive IT department or network contractor is needed to begin scanning documents to local servers or FTP locations. Email can now be delivered anywhere on the Internet (or simple fax sending and receiving) through standard phone line.
Xerox DocuMate 3920 - MFP option
MFP option - desktop
Interface Type
USB 2.0, LAN
Scan Element Type
CCD
Light Source
Xe-gas cold cathode fluorescent lamp
Additional Functions
Email, fax, scan to print, scan to network share
Max Supported Document Size
Legal (216 x 356 mm)
Input Type
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Max Document Size
216 mm x 297 mm
Automatic Duplexing
Supported Document Type
Plain paper
Document Feeder Type
Automatic
Document Storage Capacity
50 sheets
Duty Cycle
1000 scans per day
Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista
48 cm x 47.5 cm x 20.5 cm
10.2 kg
Interface Type
USB 2.0, LAN
Scanner
Input Type
Grayscale Depth (External)
Colour Depth (External)
Optical Resolution
600 dpi x 600 dpi
Scan Mode
Single/duplex pass
Automatic Duplexing
Scan Element Type
CCD
Bulb / Light Source Type
Duty Cycle
1000 scans per day
Scanner Speed Details
20 ppm - black & white - 200 dpi , 14 ipm - duplex - black & white - 200 dpi , 10 ppm - colour - 150 dpi
Scanner Features
7" touch screen TFT display
Media Handling
Max Document Size
216 mm x 297 mm
Plain paper
Supported Document Size Details
ADF - up to Legal (216 x 356 mm) , Flatbed - up to 216 x 297 mm
Automatic
50 sheets
Supported Protocols
FTP, HTTP, SMTP, HTTPS, LDAP
USB 2.0 - Type B , 2 x phone line , LAN , USB 2.0 - Type A
1 x USB cable , 1 x phone cable
External power adapter
Software Included
Network Management Tool
48 cm
47.5 cm
20.5 cm
10.2 kg
Scroll to top
