BT.com
Wishlist
Xerox Documate 3640 Pro A4 Flatbed Scanner
Xerox Documate 3640 Pro A4 Flatbed...
£1,547.79
£1,547.79
Add to wishlist
Delivery
Standard Due date unavailable
The DocuMate 3640 is a departmental duplex flatbed scanner with the automatic document feeder (ADF) that scans in duplex mode. The A4/legal flatbed is the only departmental scanner that can be programmed to automatically scan customisable applications or devices. Ultrasonic double feed detection insures that no pages are missed due to a misfeed or stapled document in the ADF tray. Documents can be converted to text-searchable PDF in one easy step.
The Xerox DocuMate 3640 is the perfect solution for company wide scanning solutions and enables businesses to achieve high levels of productivity by distributing fast, costeffective departmental scanners throughout the organization.
Xerox DocuMate 3640 - document scanner
Document scanner - desktop
Interface Type
USB 2.0
Max Supported Document Size
216 x 965 mm
Input Type
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi
Max Document Scan Speed
40 ppm (mono) / 40 ppm (colour)
Max Document Size
216 mm x 965 mm
Automatic Duplexing
Supported Document Type
Plain paper
Document Feeder Type
Automatic
Document Storage Capacity
80 sheets
Duty Cycle
5000 scans per day
Microsoft Windows 2000 SP4, Microsoft Windows XP SP2, Microsoft Windows 7, Microsoft Windows Vista
53.1 cm x 41.1 cm x 22.4 cm
10.3 kg
Interface Type
USB 2.0
216 x 965 mm
Scanner
Input Type
Grayscale Depth (External)
Colour Depth (External)
Optical Resolution
600 dpi
Scan Mode
Single/duplex pass
Automatic Duplexing
Max Document Scan Speed B/W
40 ppm
Max Document Scan Speed Colour
40 ppm
Duty Cycle
5000 scans per day
Scanner Speed Details
80 ipm - duplex black & white (back) 200 dpi (back) , 80 ipm - duplex colour (back) 150 dpi (back) , 40 ppm black & white (back) 200 dpi (back) , 40 ppm colour (back) 150 dpi (back)
Scanner Features
Visioneer OneTouch with Kofax VRS Technology
TWAIN, ISIS, WIA
Media Handling
Max Document Size
216 mm x 965 mm
Plain paper
Supported Document Size Details
ADF - up to 216 x 965 mm , Flatbed - up to Legal (216 x 356 mm)
Automatic
80 sheets
USB 2.0 - Type B
1 x USB cable
External power adapter
Software Included
QuickScan Pro (Demo), Kofax VirtualReScan Professional, Nuance OmniPage Professional, Nuance PaperPort, Visioneer OneTouch
Additional Requirements
DVD-ROM, USB port
System Requirements Details
Windows 2000 SP4 - Pentium 4 RAM 512 MB - HD 500 MB , Windows XP SP2 - Pentium 4 RAM 512 MB - HD 500 MB , Windows 7/Vista - Pentium 4 RAM 1 GB - HD 500 MB
53.1 cm
41.1 cm
22.4 cm
10.3 kg
Scroll to top
