BT.com
Wishlist
Xerox DocuMate 3220 - Document scanner - Duplex
Xerox DocuMate 3220 - Document...
£272.83
17 in stock
£272.83
Add to wishlist
Delivery
Standard 1-3 working days
The Xerox DocuMate 3220 is a next generation duplex scanner that combines an A4/US Letter sized flatbed and 50-sheet capacity ADF (Automatic Document Feeder) to create an entry level scanner with all the best features of higher-end products. It can easily support the scanning needs of individuals in small and home offices or workgroups in the corporate world. Installation is as simple as inserting one DVD-ROM disc and connecting the scanner to a host PC via a high-speed USB 2.0 cable.
The Xerox DocuMate 3220 includes a powerful and robust productivity software bundle that provides all the tools for a document centric professional who needs to better organize, manipulate and communicate paper in their business. Scan checks, documents, business cards, credit cards, photos or thick card stock with one touch simplicity. The Xerox DocuMate 3220 front panel provides simple single button control for at-device scanning to any of 9 preset and up to 99 completely customizable OneTouch scan profiles.
Xerox DocuMate 3220 - document scanner
Document scanner - desktop
Interface Type
USB 2.0
Scan Element Type
Dual CIS
Max Supported Document Size
222 x 965 mm
Input Type
Grayscale / Color Depth (External)
8-bit (256 colours) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi
Max Document Scan Speed
23 ppm (mono) / 12 ppm (colour)
Max Document Size
222 mm x 965 mm
Automatic Duplexing
Supported Document Type
Plain paper
Document Feeder Type
Automatic
Document Storage Capacity
50 sheets
Duty Cycle
1500 scans per day
AC 220 V
Microsoft Windows XP, Microsoft Windows 7, Apple MacOS X 10.4 or later, Microsoft Windows Vista, Windows 8, Windows 10
Microsoft Certification
Compatible with Windows 7
45.3 cm x 33 cm x 13.9 cm
4.6 kg
Interface Type
USB 2.0
222 x 965 mm
Scanner
Input Type
Grayscale Depth (External)
8-bit (256 colours)
Colour Depth (External)
Optical Resolution
600 dpi
Scan Mode
Single/duplex pass
Automatic Duplexing
Scan Element Type
Dual CIS
Max Document Scan Speed B/W
23 ppm
Max Document Scan Speed Colour
12 ppm
Duty Cycle
1500 scans per day
Scanner Speed Details
46 ipm - duplex black & white (back) 200 dpi (back) , 23 ppm black & white (back) 200 dpi (back) , 24 ipm - duplex colour (back) 150 dpi (back) , 12 ppm colour (back) 150 dpi (back)
Scanner Features
Visioneer OneTouch with Kofax VRS Technology
TWAIN, WIA
Media Handling
Max Document Size
222 mm x 965 mm
Plain paper
Supported Document Size Details
ADF - up to 222 x 965 mm , Flatbed - up to 216 x 299 mm
Automatic
50 sheets
USB 2.0 - Type B
1 x USB cable
External power adapter
AC 220 V
Software Included
Nuance OmniPage Professional, Nuance PaperPort, Visioneer OneTouch with Kofax VRS Technology, NewSoft Presto! PageManager, ExactScan 2 Lite
System Requirements Details
Windows XP - Pentium 4 RAM 512 MB - HD 350 MB (USB) , Windows Vista/7/8/10 - Pentium 4 RAM 1 GB - HD 350 MB (USB) , MacOS X 10.4 or later - PowerPC G5 - 1.6 GHz - RAM 512 MB - HD 350 MB (USB) , MacOS X 10.4 or later - Intel Core - 1.83 GHz - RAM 512 MB - HD 350 MB (USB)
45.3 cm
33 cm
13.9 cm
4.6 kg
Scroll to top
