BT.com
Wishlist
Xerox DocuMate 3125 Document Scanner
Xerox DocuMate 3125 Document...
£324.26
£324.26
Add to wishlist
Delivery
Standard Due date unavailable
The Xerox DocuMate 3125 is an A4 desktop document scanner with speeds of 25 ppm and 44 ipm (images per minute, duplex) in black and white, grayscale and color at 200 or 300 dpi. Durability tests support a daily duty cycle of 3,000 pages. The scanner uses a CIS (Contact Image Sensor) and an LED light source for efficient power consumption. The unit offers a 50-sheet document feeder for document widths up to 8.5". Long capability is supported up 38". The DocuMate 3125 has ultrasonic double feed detection so that stapled or other misfed documents can be sensed before they are crumpled, destroyed or cause a jam.
The DocuMate 3125 scanner allows users to scan to the "destination" of their choice by pressing a single button, eliminating the multiple steps usually required to save scanned documents in popular file formats. Simply select one of 9 preset (yet completely user configurable) and your documents will be scanned with the correct settings for resolution, color, cropping, and file format.
Xerox DocuMate 3125 - sheetfed scanner
Sheetfed scanner - desktop
Interface Type
USB 2.0
Scan Element Type
Contact Image Sensor (CIS)
Max Supported Document Size
216 x 965 mm
Input Type
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi
Max Document Size
216 mm x 965 mm
Automatic Duplexing
Supported Document Type
Plain paper, plastic card
Document Feeder Type
Automatic
Document Storage Capacity
50 sheets
Duty Cycle
3000 scans per day
Microsoft Windows Vista / XP / 7
28.4 cm x 26.1 cm x 26.1 cm
2.3 kg
Environmental Standards
ENERGY STAR Qualified
Interface Type
USB 2.0
216 x 965 mm
Scanner
Input Type
Grayscale Depth (External)
Colour Depth (External)
Optical Resolution
600 dpi
Automatic Duplexing
Scan Element Type
Duty Cycle
3000 scans per day
Scanner Speed Details
25 ppm - black & white - 200 dpi , 25 ppm - colour - 150 dpi , 44 ipm - duplex - black & white - 200 dpi , 44 ipm - duplex - colour - 150 dpi
Scanner Features
Visioneer OneTouch with Kofax VRS Technology
TWAIN, ISIS, WIA
Media Handling
Max Document Size
216 mm x 965 mm
Automatic
50 sheets
USB 2.0
1 x USB cable
EMC
Software Included
Presto! BizCard, Nuance OmniPage Professional, Nuance PaperPort, Visioneer OneTouch with Kofax VRS Technology
System Requirements Details
Windows XP - Pentium 4 RAM 512 MB - HD 350 MB , Windows 7/Vista - Pentium 4 RAM 1 GB - HD 350 MB
28.4 cm
26.1 cm
26.1 cm
2.3 kg
Scroll to top
