BT.com
Wishlist
Xerox DocuMate 3115 Scanner
£272.11
Hurry, only 1 left in stock!
£272.11
Add to wishlist
Delivery
Standard 1-3 working days
The Xerox DocuMate 3115 has all the features you expect in a powerful desktop scanner such as a 20-page automatic document feeder (ADF), 30 images per minute duplex scanning speed, and Visioneer OneTouch with Kofax VRS technology. Then at the push of a button, the DocuMate 3115 ejects from its docking station to become a full function mobile scanner. When undocked, the DocuMate 3115 can be powered by a second USB cable instead of an AC adapter, providing a true mobile experience for users on the go.
Modern offices are no longer defined by traditional walls and desks, so when your work space is not contained within four walls, you need a scanner with flexibility. Whether scanning contracts, forms, receipts, photos, ID cards, handwritten notes or virtually any document of varying size or complexity, the DocuMate 3115 does its job so you can do yours. It is the perfect companion for anyone in the fields of healthcare, real estate, construction, financial services or insurance.
If you can't search your scanned documents by their content, you might as well be looking at paper again. The DocuMate 3115 can scan automatically to searchable PDF. The Xerox DocuMate 3115 integrates Kofax VRS image enhancement technology into the OneTouch scanning process.
Xerox DocuMate 3115 - sheetfed scanner
Sheetfed scanner - desktop
Interface Type
USB 2.0
Max Supported Document Size
Legal (216 x 356 mm)
Input Type
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi
Max Document Size
216 mm x 356 mm
Automatic Duplexing
Supported Document Type
Plain paper, plastic card
Document Feeder Type
Automatic
Document Storage Capacity
20 sheets
Duty Cycle
500 scans per day
Microsoft Windows 2000, Apple MacOS X 10.4, Microsoft Windows Vista / XP / 7, Apple MacOS X 10.5 or later
Microsoft Certification
Certified for Windows Vista
29.7 cm x 11.9 cm x 12.2 cm
1.8 kg
Environmental Standards
ENERGY STAR Qualified
Interface Type
USB 2.0
Scanner
Input Type
Grayscale Depth (External)
Colour Depth (External)
Optical Resolution
600 dpi
Automatic Duplexing
Duty Cycle
500 scans per day
Scanner Speed Details
15 ppm - black & white - 200 dpi , 15 ppm - colour - 150 dpi , 30 ipm - duplex - black & white - 200 dpi , 30 ipm - duplex - colour - 150 dpi
Scanner Features
Visioneer OneTouch with Kofax VRS Technology
TWAIN, WIA
Media Handling
Max Document Size
216 mm x 356 mm
Automatic
20 sheets
USB 2.0 - Type B
Docking station
1 x USB cable
Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
ENERGY STAR Certified
Software Included
Presto! BizCard, Nuance PaperPort, Visioneer OneTouch with Kofax VRS Technology, Nuance OmniPage
Additional Requirements
DVD-ROM, USB port
System Requirements Details
Windows 2000/XP - Pentium 4 RAM 512 MB - HD 350 MB , Windows 7/Vista - Pentium 4 RAM 1 GB - HD 350 MB , MacOS X 10.4 or later - PowerPC G5 - 1.6 GHz - RAM 512 MB - HD 350 MB
29.7 cm
11.9 cm
12.2 cm
1.8 kg
Scroll to top
