Click to visit BT.com
BT.com
Wishlist
Wyse T10 Thin Client - 1 GB RAM - 1 GHz
Quicklinx: 881RWS00
Mfr#: 909566-02L
A great value from day one, the Wyse T10 sets the new standard for entry-level thin clients. Providing an exceptional user experience, the T10 features incredibly fast Wyse ThinOS, for environments in which security is critical - there's no attack surface to put your data at risk. Boot up in just seconds and log in securely to the network. The T10 delivers a superior Citrix, Microsoft and VMware VDI user experience, along with usability and management features found in premium thin clients. The T10 delivers outstanding performance based on its system-on-a-chip (SoC) design, and a built-in media processor delivers smooth multimedia, bi-directional audio and Flash playback. Flexible mounting options let you position the T10 vertically or horizontally on your desk, on the wall or behind your display. Using about 7 watts of power in full operation, the T10 creates very little heat for a greener, more comfortable working environment.
Dell Wyse T10 Thin Client - ARMADA 510 1.2 GHz - 1 GB - 0 GB
Thin client - desktop slimline
1 x Marvell ARMADA 510 / 1.2 GHz
Cache Memory
512 KB
Cache Per Processor
512 KB
RAM
1 GB DDR3 SDRAM
Flash Memory
0 GB
Hard Drive
No HDD
Audio Output
Stereo - integrated
GigE
AC 120/230 V ( 50/60 Hz )
OS Provided
Wyse Thin OS
17.7 cm x 11.9 cm x 2.5 cm
450 g
Environmental Standards
ENERGY STAR Qualified EPEAT Silver
3 years warranty
Thin client
Product Form Factor
Desktop slimline
Processor / Chipset
CPU
CPU Qty
1
Max CPU Qty
1
Cache Memory
Installed Size
512 KB
Cache Per Processor
512 KB
RAM
Installed Size
1 GB
DDR3 SDRAM
Flash Memory
Flash Memory
0 GB
Hard Drive
No HDD
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Video Interfaces
DVI
Max Monitors Supported
2
Audio Output
Integrated
Sound Output Mode
Stereo
Max Sampling Rate
48 kHz
Integrated
1 x DVI-I , 4 x USB 2.0 ( 2 in front ) , 1 x LAN (Gigabit Ethernet) , 1 x microphone , 1 x audio line-out
Horizontal feet
Theft/Intrusion Protection
FCC Class B certified, TUV GS, VCCI, C-Tick, ISO 9241-3, ISO 9241-8, EN 60950, RoHS, WEEE, cULus
Power adapter
Nominal Voltage
Operating System / Software
OS Provided
Wyse Thin OS
EPEAT Compliant
EPEAT Silver
Limited warranty - 3 years
17.7 cm
11.9 cm
2.5 cm
450 g
10 °C
35 °C
10 - 95% (non-condensing)
881R C2G 2m USB 2.0 A/B Cable - Black In Stock £3.82
881R C2G 5m USB 2.0 A/B Cable - Black In Stock £5.52
881R C2G 2-Port USB 2.0 Manual Switch In Stock £22.54
881R C2G 5m USB 2.0 A Male to A Female Active Extension Cable In Stock £15.94
881R C2G 4-Port USB 2.0 Aluminum Hub In Stock £30.25
881R C2G 12m USB 2.0 A/A Active Extension Cable In Stock £20.47
881R C2G USB Superbooster Extender Kit In Stock £40.17
881R C2G USB to HDMI Adapter with Audio Up To 1080p In Stock £42.33
