BT.com
Wishlist
Wiebe Tech Drive eRazer Ultra - Hard Drive Eraser
Wiebe Tech Drive eRazer Ultra -...
£276.97
£276.97
Add to wishlist
Delivery
Standard Due date unavailable
Completely erasing a hard drive is more complex than deleting a file or reformatting the drive. To safely sanitize your drive, you need to completely write over every bit. Otherwise, your sensitive data is there for the taking.
No computer needed
The CRU® WiebeTech® Drive eRazer™ Ultra is a stand-alone device that completely and quickly cleans hard drives. Simply connect a drive to the Drive eRazer Ultra and it will sanitize the drive faster than using software, and without tying up your computer.
The Drive eRazer Ultra leaves the drive ready for safe re-use, and comes with a dozen different preset erase procedures, including US Department of Defense graded methods for data wiping.
WiebeTech Drive eRazer Ultra - hard drive eraser
Hard drive eraser
8.1 cm x 5.6 cm x 2.4 cm
United Kingdom
2 years warranty
Hard drive eraser
8.1 cm
5.6 cm
2.4 cm
United Kingdom
LCD display
2 years warranty
Service & Support Details
Limited warranty - 2 years , Technical support - phone consulting - 90 days
Scroll to top
