Click to visit BT.com
BT.com
Wishlist
WD Red 3TB NAS Desktop Hard Disk Drive - Intellipower SATA 6Gb/s 64MB Cache 3.5 Inch - WD30EFRX
Use vouchercode 860210816 and save £10 at checkout!
Limited Time Offer
5.0*
Quicklinx: 8602WS00
Mfr#: WD30EFRX
Form Factor: 3.5" x 1/3H
Type: Hard drive
Interface Type: Serial ATA-600
Capacity: 3TB
Spin Speed (rpm): 5400rpm
Express delivery Delivered on Wednesday
17 in stock
£99.99
Essential accessories
WD Red™: The new colour of NAS.
WD Red is the only hard drive designed for NAS systems that have 1-5 drive bays. Available in capacities ranging from 1 TB to 3 TB, WD Red is designed specifically for home and small office NAS systems. The drives are extensively tested for compatibility and reliability in the demanding operating environment of a 24x7 NAS system. WD's exclusive NASware™ firmware technology enables seamless integration and balanced performance. Innovative technology reduces power comsumption and lowers the operating temperature, and with a 35% improvement in MTBF over desktop drives, WD Red is a more reliable and robust NAS hard drive solution.
  • Designed specifcally for home and small office NAS systems - WD Red is the only hard drive for 1-5 bay systems
  • Exclusive NASware™ technology - advanced firmware for seamless integration and optimal performance
  • Energy efficient and reliable - Innovative technology reduces power consumption and operating temperature
Spec
  • Windows® XP/Vista/7, Mac® OS Note: Compatibility may vary depending on user's hardware configuration and operating system.
  • 3-year limited warranty
The New WD Caviar Red Hard Drives: Features
Introducing The New WD Caviar Red Hard Drives: The New Colour of NAS
WD Red NAS Hard Drive WD30EFRX - hard drive - 3 TB - SATA 6Gb/s
Hard drive - internal
3 TB
3.5" x 1/3H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
64 MB
IntelliPower, Advanced Format technology, NAS compatible, NASware technology, 3D Active Balance Plus , S.M.A.R.T.
101.6 mm x 147 mm x 26.1 mm
640 g
3 years warranty
My Cloud EX2; EX4
3 TB
3.5" x 1/3H
SATA 6Gb/s
Buffer Size
64 MB
101.6 mm
147 mm
26.1 mm
640 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
147 MBps
Reliability
MTBF
1,000,000 hour(s)
Non-Recoverable Errors
1 per 10^14
Start / Stop Cycles
600,000
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bays
1 x 3.5" x 1/3H - internal
Power Consumption
4.1 Watt ( read ) , 4.1 Watt ( write ) , 2.7 Watt ( idle ) , 0.4 Watt ( sleep )
RoHS
Limited warranty - 3 years
65 °C
Shock Tolerance
65 g @ 2ms (operating) / 250 g @ 2ms (non-operating)
Sound Emission
23 dBA
WD My Cloud EX2 , WD My Cloud EX4
WD Red 3TB NAS Desktop  Hard Disk Drive - Intellipower SATA 6Gb/s 64MB Cache 3.5 Inch - WD30EFRX Bundle deal on WD Red 3TB NAS Desktop Hard Disk Drive - Intellipower SATA 6Gb/s 64MB Cache 3.5 Inch - WD30EFRX
Including:
CoolerMaster High Performance Thermal Paste 2g CoolerMaster High Performance Thermal Paste 2g worth £4.83 | in stock
Akasa Cable Tidy Kit Akasa Cable Tidy Kit worth £4.20 | in stock
StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit worth £11.61 | in stock
Best Value Duratool Antistatic Wrist Band Best Value Duratool Antistatic Wrist Band worth £3.60 | while stocks last
C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable worth £3.58 | in stock
£119.52
saving £8.26
Cables (1)
Cables
Including:
£101.77
saving £1.78
Other bundles (2)
Including:
£101.79
saving £1.80
Including:
Intenso 32GB Rainbow Transparent USB Flash Drive Intenso 32GB Rainbow Transparent USB Flash Drive worth £5.48 | in stock
£104.08
saving £1.39
8602 StarTech.com 3.5in Black USB 3.0 External SATA III Hard Drive Enclosure with UASP for SATA 6 Gbps In Stock £33.72
8602 StarTech.com USB 3.0/eSATA Dual 3.5" SATA III Hard Drive External RAID Enclosure w/ UASP - Black In Stock £79.81
8602 StarTech.com 3 Bay Aluminum Trayless Hot Swap Mobile Rack Backplane for 3.5in SAS II/SATA III In Stock £76.44
Resources
The following resources are available for the WD Red 3TB NAS Desktop Hard Disk Drive - Intellipower SATA 6Gb/s 64MB Cache 3.5 Inch - WD30EFRX
Customer reviews
Write a review for the WD Red 3TB NAS Desktop Hard Disk Drive - Intellipower SATA 6Gb/s 64MB Cache 3.5 Inch - WD30EFRX here!
WD 3TB Red SATA 6Gb/s 64MB 3.5" Hard Drive
Reviewed by John. Review Posted 13/04/2013
A great and reliable hardrive for the job!
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
Finally a drive for NAS
Reviewed by Anonymous Review Posted 29/10/2012
This is a great drive for home users with a NAS (network attached storage).
I have a D-Link Sharecenter 320 running a pair of 1 year old regular drives and while ok they weren't built for the job, running hot and slow data rates.
I got the latest firmware from D-link, inserted the drive into the enclosure and it worked straight away without any problems.
So far data transfer rates are 3-4 times faster than the drives that were replaced and so far the drive hasn't needed cooling once.
Also given it comes with a 3 year warrenty from WD they are confident that these drives will do the job.
  • Overall 5*
  • Ease of use 5*
Inspire confidence
Reviewed by Dan P. Review Posted 22/09/2014
Bought a pair of these to use as a 3TB RAID 1 array for my NAS enclosure.
They are fast, quiet, they run cool, and they are good value for money at £89 a piece. Also had nothing but good service from WD drives over the years, so am confident these will be the same.
  • Overall 5*
  • Ease of use 5*
Excellent
Reviewed by PavT. Review Posted 30/07/2015
I got this drive to use as a mass backup / storage using a bare drive adapter. It is fast and quiet. Would thoroughly recommend it.
  • Overall 5*
  • Ease of use 5*
Fast and Quiet but had a failure
Reviewed by Anonymous Review Posted 11/08/2015
These drives are specifically designed for NAS drives and I purchased 2 in April 2013 for use in my Synology 213+ disk station running in RAID 1 mode.
In combination they have been quick quiet and efficient and I would have given them 5 stars.
However I just had one fail after just over two years use. The first sign was an intermitent "grinding" sound which soiunded like the fan failing. However a week later Disk 1 has fallen out of the RAID with bad sectors and disk unreachable errors.
Hopefully this isn't a sign of things to come with Disk 2.
Due to the failure within the wrranty period I'm dropping my score to 4 stars. It will be interesting to see how WD's warranty works in practice as the terms seem designed to make claiming difficult
  • Overall 4*
  • Ease of use 5*
  • Value for money 4*
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
Type: Hard drive
Capacity: 3TB
Brand: WD
Price Range Inc VAT: 50 - 100
