BT.com
Wishlist
WD Red 2TB NAS Desktop  Hard Disk Drive - Intellipower SATA 6 Gb/s 64MB Cache 3.5 Inch - WD20EFRX
WD Red 2TB NAS Desktop Hard Disk...
Free delivery
£79.99
Free delivery
13 in stock
£79.99
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered on Tuesday
Express Delivery
  • 00 h
  • 00 m
  • 00 s
WD Red™: The colour of NAS.
WD Red is designed for NAS systems that have 1-8 drive bays. Available in capacities ranging from 1TB to 8TB, WD Red is designed specifically for home and small office NAS systems. The drives are extensively tested for compatibility and reliability in the demanding operating environment of a 24x7 NAS system. WD's exclusive NASware™ firmware technology enables seamless integration and balanced performance. Innovative technology reduces power comsumption and lowers the operating temperature, and with a 35% improvement in MTBF over desktop drives, WD Red is a more reliable and robust NAS hard drive solution.
• Designed specifcally for home and small office NAS systems - WD Red is the only hard drive for 1-8 bay systems
• Exclusive NASware™ technology - advanced firmware for seamless integration and optimal performance
• Energy efficient and reliable - Innovative technology reduces power consumption and operating temperature
WD Red NAS Hard Drive WD20EFRX - hard drive - 2 TB - SATA 6Gb/s
Hard drive - internal
2 TB
3.5" x 1/3H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
64 MB
IntelliPower, Advanced Format technology, NAS compatible, NASware technology, 3D Active Balance Plus, S.M.A.R.T.
10.2 cm x 14.7 cm x 2.6 cm
600 g
3 years warranty
My Cloud EX2; EX4
2 TB
3.5" x 1/3H
SATA 6Gb/s
Buffer Size
64 MB
10.2 cm
14.7 cm
2.6 cm
600 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
147 MBps
Reliability
MTBF
1,000,000 hour(s)
Non-Recoverable Errors
1 per 10^14
Start / Stop Cycles
600,000
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
3.5" x 1/3H
Power Consumption
4.1 Watt (read) , 4.1 Watt (write) , 2.7 Watt (idle) , 0.4 Watt (sleep)
RoHS
Limited warranty - 3 years
65 °C
Shock Tolerance
65 g @ 2ms (operating) / 250 g @ 2ms (non-operating)
Sound Emission
23 dBA
WD My Cloud EX2 , WD My Cloud EX4
WD Red 2TB NAS Desktop Hard Disk Drive - Intellipower...
£79.99
Save on this ideal PC Build kit!
Save £8.29
£99.16
Cables - Cables
£79.99
Save 50% On This 1m SATA Cable When Bought With This Item
Save £3.22
£83.21
Other bundles
£79.99
Save on Intel Optane 16GB with HDD
Save £5.00
£119.97
Accessories
£37.11
£87.73
£89.43
Resources
The following resources are available for the WD Red 2TB NAS Desktop Hard Disk Drive - Intellipower SATA 6 Gb/s 64MB Cache 3.5 Inch - WD20EFRX
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Good sound hard drive
Reviewed by Bergamot Eng. on 23/09/2013
Quiet drive.
Smooth installation.
No worries
5* Very satisfactory mid-range disk
Reviewed by Martin Baxter on 21/07/2013
This disk is part of Western Digital's new "Red Caviar" range, which sits between "Green" (basic) and "Black" (higher-spec). The manufacturers suggest that it is well-suited to NAS (network attached storage) use.
I bought two of these to put into my Synology DS209+II (two-bay NAS with RAID1) so to increase its capacity. Installation was fine and the existing data copied across quite quickly (1TB in 3 hours).
Everything is looking good - the NAS now has twice its previous capacity and all looks good.
One caution: due to HDD quoting conventions and other factors, you can only expect to get about 1.8TB of usable space from disk drives described as "2TB".
Scroll to top
