Click to visit BT.com
BT.com
Wishlist
WD Red 2TB NAS Desktop Hard Disk Drive - Intellipower SATA 6 Gb/s 64MB Cache 3.5 Inch - WD20EFRX
5.0*
Quicklinx: 8601WS00
Mfr#: WD20EFRX
Form Factor: 3.5" x 1/3H
Type: Hard drive
Interface Type: Serial ATA-600
Capacity: 2TB
Spin Speed (rpm): 5400rpm
Express delivery Order within the next 20 hours for delivery on Wednesday
More than 50 in stock
£84.82
Essential accessories
WD Red™: The new colour of NAS.
WD Red is the only hard drive designed for NAS systems that have 1-5 drive bays. Available in capacities ranging from 1 TB to 3 TB, WD Red is designed specifically for home and small office NAS systems. The drives are extensively tested for compatibility and reliability in the demanding operating environment of a 24x7 NAS system. WD's exclusive NASware™ firmware technology enables seamless integration and balanced performance. Innovative technology reduces power comsumption and lowers the operating temperature, and with a 35% improvement in MTBF over desktop drives, WD Red is a more reliable and robust NAS hard drive solution.
  • Designed specifcally for home and small office NAS systems - WD Red is the only hard drive for 1-5 bay systems
  • Exclusive NASware™ technology - advanced firmware for seamless integration and optimal performance
  • Energy efficient and reliable - Innovative technology reduces power consumption and operating temperature
Spec
  • Windows® XP/Vista/7, Mac® OS Note: Compatibility may vary depending on user's hardware configuration and operating system.
  • 3-year limited warranty
The New WD Caviar Red Hard Drives: Features
Introducing The New WD Caviar Red Hard Drives: The New Colour of NAS
WD Red NAS Hard Drive WD20EFRX - hard drive - 2 TB - SATA 6Gb/s
Hard drive - internal
2 TB
3.5" x 1/3H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
64 MB
IntelliPower, Advanced Format technology, NAS compatible, NASware technology, 3D Active Balance Plus , S.M.A.R.T.
10.2 cm x 14.7 cm x 2.6 cm
600 g
3 years warranty
My Cloud EX2; EX4
2 TB
3.5" x 1/3H
SATA 6Gb/s
Buffer Size
64 MB
10.2 cm
14.7 cm
2.6 cm
600 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
147 MBps
Reliability
MTBF
1,000,000 hour(s)
Non-Recoverable Errors
1 per 10^14
Start / Stop Cycles
600,000
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bays
1 x 3.5" x 1/3H - internal
Power Consumption
4.1 Watt ( read ) , 4.1 Watt ( write ) , 2.7 Watt ( idle ) , 0.4 Watt ( sleep )
RoHS
3 years warranty
Service & Support Details
Limited warranty - 3 years
65 °C
Shock Tolerance
65 g @ 2ms (operating) / 250 g @ 2ms (non-operating)
Sound Emission
23 dBA
WD My Cloud EX2 , WD My Cloud EX4
WD Red 2TB NAS Desktop  Hard Disk Drive - Intellipower SATA 6 Gb/s 64MB Cache 3.5 Inch - WD20EFRX Bundle deal on WD Red 2TB NAS Desktop Hard Disk Drive - Intellipower SATA 6 Gb/s 64MB Cache 3.5 Inch - WD20EFRX
Including:
CoolerMaster High Performance Thermal Paste 2g CoolerMaster High Performance Thermal Paste 2g worth £4.83 | in stock
Akasa Cable Tidy Kit Akasa Cable Tidy Kit worth £4.62 | in stock
StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit worth £11.61 | in stock
Best Value Duratool Antistatic Wrist Band Best Value Duratool Antistatic Wrist Band worth £3.60 | while stocks last
C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable worth £3.58 | in stock
£104.35
saving £8.68
Cables (1)
Cables
Including:
£86.60
saving £1.78
Options (2)
Including:
£86.62
saving £1.80
Including:
Corsair Flash Voyager Slider - 32GB - USB 3.0 Corsair Flash Voyager Slider - 32GB - USB 3.0 worth £9.88 | in stock
£94.81
8601 StarTech.com 3.5in Black USB 3.0 External SATA III Hard Drive Enclosure with UASP for SATA 6 Gbps In Stock £33.72
8601 StarTech.com USB 3.0/eSATA Dual 3.5" SATA III Hard Drive External RAID Enclosure w/ UASP - Black In Stock £79.81
8601 StarTech.com 3 Bay Aluminum Trayless Hot Swap Mobile Rack Backplane for 3.5in SAS II/SATA III In Stock £76.44
Resources
The following resources are available for the WD Red 2TB NAS Desktop Hard Disk Drive - Intellipower SATA 6 Gb/s 64MB Cache 3.5 Inch - WD20EFRX
Customer reviews
Write a review for the WD Red 2TB NAS Desktop Hard Disk Drive - Intellipower SATA 6 Gb/s 64MB Cache 3.5 Inch - WD20EFRX here!
Good sound hard drive
Reviewed by Bergamot Eng.. Review Posted 23/09/2013
Quiet drive.
Smooth installation.
No worries
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
Very satisfactory mid-range disk
Reviewed by Martin Baxter. Review Posted 21/07/2013
This disk is part of Western Digital's new "Red Caviar" range, which sits between "Green" (basic) and "Black" (higher-spec). The manufacturers suggest that it is well-suited to NAS (network attached storage) use.
I bought two of these to put into my Synology DS209+II (two-bay NAS with RAID1) so to increase its capacity. Installation was fine and the existing data copied across quite quickly (1TB in 3 hours).
Everything is looking good - the NAS now has twice its previous capacity and all looks good.
One caution: due to HDD quoting conventions and other factors, you can only expect to get about 1.8TB of usable space from disk drives described as "2TB".
  • Overall 5*
  • Ease of use 5*
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
Type: Hard drive
Capacity: 2TB
Brand: WD
Price Range Inc VAT: 50 - 100
