BT.com
Wishlist
WD Purple NV 4TB Surveillance AV Hard Disk Drive Intellipower SATA 6 Gb/s 64MB Cache 3.5 Inch
WD Purple NV 4TB Surveillance AV...
£146.11
£146.11
Add to wishlist
Delivery
Standard Due date unavailable
Designed specifically for NVR digital surveillance systems, the WD Purple NV hard drive adds support for systems with higher drive bay configurations and up to 64 HD cameras. The increased number of video streams and workload capability offered with the WD Purple NV hard drive allows scalability beyond the limitations of DVR systems where only the WD Purple drive is applicable.
WD Purple NV Surveillance Hard Drive WD4NPURX - hard drive - 4 TB - SATA 6Gb/s
Hard drive - internal
4 TB
3.5" x 1/3H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
64 MB
IntelliSeek, IntelliPower, Advanced Format technology, AllFrame, surveillance system compatible, S.M.A.R.T.
101.6 mm x 147 mm x 26.1 mm
720 g
3 years warranty
4 TB
3.5" x 1/3H
SATA 6Gb/s
Buffer Size
64 MB
101.6 mm
147 mm
26.1 mm
720 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
150 MBps
Reliability
Non-Recoverable Errors
1 per 10^14
Load / Unload Cycles
300,000
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
3.5" x 1/3H
Power Consumption
4.8 Watt (read) , 4.8 Watt (write) , 4.33 Watt (idle) , 0.52 Watt (stand by) , 0.52 Watt (sleep)
Apple MacOS, Microsoft Windows 7 / Windows 8
RoHS, NMB-3 Class B, CAN ICES-3 Class B
Limited warranty - 3 years
65 °C
Shock Tolerance (operating)
30 g @ 2 ms
Shock Tolerance (non-operating)
250 g @ 2 ms
Sound Emission
25 dBA
WD Purple NV 4TB Surveillance AV Hard Disk Drive...
£146.11
Save on this ideal PC Build kit!
Save £10.63
£165.28
Cables - Cables
£146.11
Save 50% On This 1m SATA Cable When Bought With This Item
Save £3.22
£149.33
Scroll to top
