WD Livewire 4-Port Powerline AV Network Kit
Standard Due date unavailable
WD Livewire Powerline AV Network Kit
WD Livewire powerline AV network kit extends the Internet to any room using your home's electrical outlets. Stream the highest quality HD video, play games, and transfer files within the home or over the Internet using secure and reliable high-speed connections. Get the performance of a wired network without running wires.
Expand your home network instantly without running wires - Create high-speed Internet connections anywhere in your home without running wires between rooms. Just use your home's electrical wiring to create a network.
Set-up is as easy as plugging in a lamp - Plug one adapter into your router and an electrical outlet. Plug the other adapter into an electrical outlet in any room where you want a high-speed connection.
Faster and more reliable than wireless - With speed up to 200 megabits per second*, the WD Livewire powerline AV network kit is fast enough for every computer in your home to share your broadband Internet connection and still have the velocity you need to smoothly stream 1080p Full-HD video to your TV.
*200 Mb/s is the ideal physical data rate. Network traffic, interference, building materials, and other conditions lower actual data throughput rate.
More ports for more devices - The WD Livewire adapter kit offers four ports on both devices in the pair. This allows you to plug in your router and up to seven Internet-connected devices such as computers, TVs, game consoles, media players, and network storage drives.
Encrypted for security - The data transfer between the WD Livewire adapters is protected with the same 128-bit encryption that you trust for your online banking and shopping. And because the encryption is automatic, there's no need to remember a password.
Kit contains
- Two 4-port HomePlug AV adapters
- Two Ethernet cables
- Two power cables
- Quick Install Guide
- CD with WD Livewire utility software
- Warranty and support guide
Ethernet, HomePlug AV Compatible
Physical Dimensions (mm - H x D x W)
32 x 119 x 86
AC Input Voltage
100-240 VAC
AC Input Frequency
50-60 Hz
Ethernet router, AC Power Outlet
IEEE 802.3, IEEE 802.3u compliant
The following resources are available for the WD Livewire 4-Port Powerline AV Network Kit
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Worked straight out of the box
Reviewed by Anonymous on 24/11/2011
The devices are quite small and feel well constructed.
When I got them, I plugged then in to the mains and Ethernet and they worked right away giving much better throughput than my wifi at the far side of the house.
The only minor quibble was that the configuration software (needed if you want to change defaults) doesn't run under Linux and fails to find the devices when ran under VirtualBox in a NAT configuration so needed a little fiddling to work for me.
Scroll to top
