BT.com
Wishlist
WD Blue 750GB Mobile 7.0mm Hard Disk Drive - 5400RPM SATA 6Gb/s 2.5 Inch - WD7500LPCX
WD Blue 750GB Mobile 7.0mm Hard...
£69.26
Hurry, only 1 left in stock!
£69.26
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered on Monday
Express Delivery
  • 00 h
  • 00 m
  • 00 s
WD Blue drives are designed and manufactured with the proven technology found in WD's original award-winning desktop and mobile hard drives. Built to the highest standards of quality and reliability, these drives offer the features and capacity ideal for your everyday computing needs. These drives are available in a broad range of capacities, cache sizes, form factors and interfaces so you can be sure there's a drive that's the perfect fit for your system, in more ways than one.
WD Blue WD7500LPCX - hard drive - 750 GB - SATA 6Gb/s
Hard drive - internal
750 GB
2.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
16 MB
Spindle Speed
5400 rpm
S.M.A.R.T.
69.85 mm x 100.2 mm x 7 mm
90 g
2 years warranty
750 GB
2.5"
SATA 6Gb/s
Buffer Size
16 MB
S.M.A.R.T.
69.85 mm
100.2 mm
7 mm
90 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
140 MBps
Average Latency
5.5 ms
Spindle Speed
5400 rpm
Reliability
Non-Recoverable Errors
1 per 10^14
Start / Stop Cycles
600,000
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5"
RoHS
60 °C
Shock Tolerance
350 g @ 2ms (operating) / 1000 g @ 2ms (non-operating)
Cables - Cables
WD Blue 750GB Mobile 7.0mm Hard Disk Drive - 5400RPM...
£69.26
Save 50% On This 1m SATA Cable When Bought With This Item
Save £3.25
£72.51
Other bundles
£69.26
Save on Intel Optane 16GB with HDD
Save £5.00
£107.56
Scroll to top
