BT.com
Wishlist
WD Blue 500GB Mobile 7.0mm Hard Disk Drive - 5400RPM SATA 6Gb/s 2.5 Inch - WD5000LPVX
Last Few Remaining
Price Drop
Price Drop!
Delivery
Standard Due date unavailable
WD Blue hard drives deliver solid performance and reliability while providing you with all the space you need to hold an enormous amount of photos, videos and files. This drive is designed for use as primary drives in notebooks and external enclosures.
WD Blue WD5000LPVX - hard drive - 500 GB - SATA 6Gb/s
Hard drive - internal
500 GB
2.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
8 MB
Spindle Speed
5400 rpm
NoTouch ramp load technology, S.M.A.R.T.
69.85 mm x 100.2 mm x 7 mm
90 g
2 years warranty
500 GB
2.5"
SATA 6Gb/s
Buffer Size
8 MB
69.85 mm
100.2 mm
7 mm
90 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
147 MBps
Average Latency
5.5 ms
Spindle Speed
5400 rpm
Reliability
Non-Recoverable Errors
1 per 10^14
Start / Stop Cycles
600,000
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
2.5"
Power Consumption
0.13 Watt (idle)
RoHS
60 °C
Shock Tolerance
400 g @ 2ms (operating) / 1000 g @ 2ms (non-operating)
Sound Emission
17 dBA
Scroll to top
